Dynamic Array with previous info in recordset
Thread began 5/28/2009 1:05 pm by xag | Last modified 7/31/2009 11:43 am by jason312679 | 7652 views | 11 replies |
xag
Hello,
I wanted to know if you create a dynamic array if your field b and c could still show information from a previous record set.
Let me explain. I have an update page. I want to go in and edit some things but not change anything in my list a through c. when I hit the edit button dataassist update function puts into the table null because I never chose anything. I want to have the list already populated with information already in the recordset. This works for list A but does not populate list b or c.
Thanks for the help
use the "populate list from array" and "set selection in list" behaviors onload so that they are set properly after the page submit.
xag
the only thing I see in my Behaviors panel when I have list A clicked is onChange Populate List from Array I don't see set selection in list. Also I want them to populate themselves when the previous page is submited and passes a parm with the id of the record set in the URL to populate the list
That is because onChange you don't have to set the selection in the list... the list selection is being set by the user.
You should be able to do it with a passed parameter as well. Are you only passing the ID of list c? you would probably have to create a recordset to look up the value for list a and list b so that you could set those selections as well, but it would work.
xag
Well list List A is set by the user but I'm trying to change that as well. I want list A in my update page to display the data already in my recordset.
xag
When I look in the properties panel and choose dynamic and set the vale equale to the item I want shown it wont display. It only displays the list from my other record set that I have the options from
You should only be using the dynamic properties panel attribute for the first list.
The rest of the lists will have to be done with the "populate list from array" and "set selection in list" behaviors onload so that they are set properly after the page submit.
xag
hi Ray when I put the "set selection in list I don't see the option onLoad. and when I type it in also DW prompts me with an error saying onLoad is not a valid event for the SELECT tag
That is because you should be highlighting the body tag to add onload events.
xag
ok so what if the body tag is not editable because it is restricted by a page template? Am I S.O.L then?
