Adding items to cart by size/price
Thread began 5/28/2009 8:01 am by jenbar3378469 | Last modified 7/01/2009 1:18 pm by dacker1313513 | 3447 views | 9 replies |
jenbar3378469
Hi, Can someone tell me how to add items using ecart, php, dreamweaver when there are different sizes and the different sizes have different prices? For example, we sell a shirt that comes in med, large and Xlarge. The med & large sizes cost $29.00, but the XLarge costs $31.00. How could the "add to cart" button be set up so that once XLarge is selected from the pull-down menu (the select list) the price of $31.00 would automatically populate in the shopping cart?
Please help.
Thanks!
You could have the additional price stored in the database with the size option it corresponds to.
Then when the add to cart form is submitted with that option selected, add a recordset above the add to cart to get the additional price associated with that option and add it to the cart instead of the base price. You could either add it to the price, store the adjusted price, or have an extra column in the cart for OptionPrice... all should work.
jenbar3378469
Thanks again Ray, but how do I store the adjusted price? And with the option you discussed, do you mean put a hidden field above the "add to cart" button with the price difference attached? How would I call this out in the code? Thanks again!
You would store the adjusted price in a column in your database just like the options themselves.
No hidden field. Filter a recordset with the list of sizes and use the recordset directly without a hidden field.
jenbar3378469
Thanks Ray! I think I understand this now!
jenbar3378469
Ray, I know I said I understand, but I tried to do it and it is not working. Right now I have my database set up so that each color of each shirt has is on it's own line with it's own item id. Is this set up incorrectly? Should I set the database up differently for instance, should I have Men's Shirt, then a size M column, a size L column, a size XL column along with separate price columns?
Also where do I filter the recordset, on the add to cart or the actual drop down menu? Filtering on the actual drop down menu only allows you to use one filter though, so I am now sooo confused. Please help!
Thanks!
You can use any database schema that works for your application. I can't claim to know enough about your business or product line to design the correct database for you with the limited information I have. If the database structure avoids repeated data that can be out of synch and encapsulates all of the data you will need to build your application, then it is good.
Get the dropdown menu populated with your color choices first. Don't worry about how you will tie it to the cart. If you have your list populated so the form looks correct then you are ready to move on to the next step.
Set the values of the list where your choices appear to the ID field in the database for the corresponding row in the table where you will find the new price.
Then you can create a new recordset on top of that page and filter it with the list id that is submitted in the form. That recordset then could return the new price column which you could bind in the add to cart button.
dacker1313513
I'm having a simular problem. I have 1 item, 4 different sizes. I can't seem to associate a dropdown list with a add to cart button. There has got to be a way to do this.
Use the dropdown list to filter a recordset that you add to the page.
Then refer to that recordset in your add to cart.
dacker1313513
Thank you.
