Can't Apply Repeat Selection SB
Thread began 5/27/2009 10:53 pm by lee266802 | Last modified 5/28/2009 6:17 pm by Ray Borduin | 1241 views | 3 replies |
lee266802
When I try to apply the Repeat Selection SB I get the error message message_1.gif. When I click "Yes" I get the error message message_2.gif.
What version of DW, DataAssist, and what OS are you using? I'll try to reproduce the problem and see what I can find. You may want to try submitting a support incident. It could be a problem with the template you are using as well.
lee266802
Dreamweaver CS4, DataAsist 2.0.4 and Vista Ultimate.
I detached the page from the template and applied the SB and had a look at what code it added, and I can see no reason why it wouldn't have been able to write code in those areas.
This may be a bug. Please post a support incident. Even if DW is mistaken in throwing the error we should be able to code around it. It doesn't seem to happen all the time, so make sure to include a copy of your template in the post so we can try to reproduce it.
