XML layout
Thread began 5/24/2010 2:48 am by steve28697 | Last modified 5/25/2010 10:42 am by Jimmy Wu | 1030 views | 1 replies |
steve28697
XML layout
Hello there,
Can WebAssist or indeed anyone offer me a sample XML syntax/layout for correct retrieval of coordinates within the XML file?
I'm stumped, and cannot get the map tp retrieve anything from the XML file itself.
Many thanks,
Steve Day
Jimmy Wu
If you're referring to the _promaps_geocache.xml file, you shouldn't be adding points directly to the xml file. You should open the map in Pro Maps (click on map placeholder and click edit) and then add the coordinates there. The xml file is just to prevent the need to contact the Google geocache server as often, so it stores information there instead.
