checkbox data not updating
Thread began 5/13/2010 7:18 am by info97301 | Last modified 5/26/2010 10:59 am by Jason Byrnes | 3162 views | 11 replies |
info97301
Hi
I created a form with DataAssist, which works fine.
I then added some fields in the database table (enum field type, 'yes' or 'no', 'no' by default)
I returned to the form and added checkboxes for the additional fields, altered the update behaviour etc etc.
However, the fields are not updated if I try to change any of them.
If I make a change direct in the database, then the changes are reflected when the page opens (i.e. certain fields will be checked), so the retrieving part of the page is working properly.
In the form, the checked value = yes :
<input <?php if (!(strcmp($row_WADAlistings['MobilityIcon'],"yes"))) {echo "checked=\"checked\"";} ?> name="ckmobility" type="checkbox" id="ckmobility" value="yes" />
In the update behaviour, the update field is set to type 'text, with the value such as the following:
<?php echo ((isset($_POST["ckmobility"]))?$_POST["ckmobility"]:""); ?>
I have even tried creating a new page just with the checkboxes on, but this doesn't work either (I note it defaults to checkbox value = '1'', do I need to change the field format in the database? Not a problem as I'm still developing at the moment)
TIA
Cheers
Chris
please send a copy of your page so I can examine the code in its entirety.
info97301
Hi Jason
txt file attached. You will not I've started trying radio buttons in addition to checkboxxes - these don't work either!
Cheers
Chris
I dont see any attached file.
Please compress the php file into a zip archive and attach the zip file to your reply.
info97301
Oops! Hopefully this gets there
Chris
listings_Update2.zip
try changing the no option:
<input <?php if (!(strcmp($row_WADAlistings['MobilityIcon'],"no"))) {echo "checked=\"checked\"";} ?> type="radio" name="ckmobility" id="radio2" value="no" />
value to blank:
<input <?php if (!(strcmp($row_WADAlistings['MobilityIcon'],"no"))) {echo "checked=\"checked\"";} ?> type="radio" name="ckmobility" id="radio2" value="" />
Then in the Update record server behavior, set the data type for the checkbox column to be Checkbox Yes/ No
info97301
Hi Jason
No good - didn't make any difference.
However, I have tried removing the WA Update process and applied the Dreamweaver Update process and it all works fine!
Cheers
Chris
can you send a copy of the dream weaver update page, this may help me determine why data assist was not working.
info97301
Hi Jason
File attached. You will notice I've changed them all to radio buttons!
Cheers
Chris
listings_Update.zip
biz295654WebAssist
what was the solution to this? it may be related to what I'm trying to fix...thanks
