For what it's worth dept.
Thread began 5/07/2010 11:21 am by Peter | Last modified 5/07/2010 11:51 am by Peter | 740 views | 2 replies |
Peter
I have a couple items for the the WA suggestion box. First, before the re-design of the web site (which looks very nice) I used to be able to see all of my extensions along with their serial numbers on one page. I can't seem to be able to do that anymore. I have to go into the page for each extension. If I can still do that somewhere, I'd like to hear how. If I can't I suggest WA make that option available again. Secondly, I want to say that WA has done a tremendous job trying to improve the support documentation for each of the products. There still in my mind as a real newcomer to much of the technology a fundamental problem with the instructions--even solution recipes--not tailored to the most basic user. That is, stepping someone through a procedure at the most basic level. I know, because I'm at that level and as I go through much of the help documents, there frequently are steps that are too short and assume someone knows how to implement that step. As only one example, I'm looking at the Security Assist getting started file. Step 1 is pretty straightforward, no problem there. I get to step 2 and it says choose the database connection you intend to use. Well, how do I do that?? I have the solution recipe files, but the starter ones anyway don't have a database connection made in the server behavior panel yet. So I don't know how to implement this step. What step 2 should do is say for people like me something like, OK now we're going to set up a database connection using the BSM starter files and here are the steps to do this. My point is, you must tailor your products including continued improvement of the tutorial files to the lowest common denominator like me because we are your clients too. I would gladly volunteer to review your tutorial documents, new or upgrading, free of charge and provide you feedback if it meant I and many others like me got the support docs we need to successfully use your products right out of the box with the least amount of hand-wringing and wheel-spinning. I think WA products have a lot of untapped potential for me and I own many, but I frequently spend too much time trying to step through the instructions. That is very frustrating and unnecessary with the proper tutorials. I'm sure hearing this after the great improvements you have made is also frustrating. I'm trying to help you and me by sharing this and point out the need to keep working on this. It's getting there, but not there yet for many of your products. Whatever it takes, please keep striving to improve in this area. Thanks for listening.
Neil Beadle
Thanks for your feedback. It is appreciated and we are working towards filling in some of these holes.
We have a number of resources for beginners to learn how to use databases so that they can succeed with our products. These are all available on the Support Home Page of our website support/.
Free eCommerce MySQL Database
ecommerce-database
Database Starter Kit for PHP
database-for-php
Managing your live database settings
change_db_pass.htm
Create a database connection in Dreamweaver
creating_db_connection.php
Importing a database (.SQL) file (PDF)
importing_sql.pdf
Peter
I know you are and I am familiar with many of these already and have been helpful. I still think though to some extent the documentation for individual extensions should be consistent in how the form in which they provide tutorials (e.g. step-by-step hands-on exercises using real-world examples) AND the documents be as standalone as possible with the needed details at each step provided to successfully do that step. I think I'm running on and you probably get what I'm saying. Do consider if you aren't doing already, including in your quality control preparing these guides draft reviews by a range of user abilities. Take it for what it's worth, I am still struggling with tutorials on a regular basis, recognizing some are more tailored for my kind than others. Thanks again for listening... and responding so quickly. That was appreciated.
