Add to Cart Buttons
Thread began 5/24/2009 12:44 am by deanmaury365211 | Last modified 5/26/2009 9:37 am by Ray Borduin | 1233 views | 1 replies |
deanmaury365211
Add to Cart Buttons
I'll try to explain this the best I can. I have 1 page with multiple items on it that works proper when hitting the add to cart button, meaning it adds the right item to the cart. The reason I believe this page works and not my others is because it works out of 1 recordset and in a repeat region. The pages that don't work, I cannot use a repeat region on, because I have lists and what not in the page. They are different packages offered and don't contain the same info. The general info is the same and can be repeated, but the rest cannot be. I created two different recordsets to control each and drug the bindings out to each and created two separate buttons for each. The problem is that when you hit either button, it only adds the 1 package for both buttons. How can I do this without a repeat region on the page, or can't it be done? 2 recordsets on the page with two different values entered, why can't it differenciate between the two packages?
This is a update to the above, I've separated the above to their own pages. I have a form on the page with a add to cart button. When the form is submitted it's supposed to send the info in a email and redirect to the cart for payment. It's sending the info to the email, but it won't redirect or add to the cart. The button is set to redirect to the cart, the email is set to send on current page submit with no redirection. A few of my other forms are set the same exact way and work fine, but I have two that refuse to. I even copied and pasted the code from a working form and fixed the code to reflect the specifics, to no avail. I think I've tried everything possible, unless you can think of something, I've missed. Thanks
Dean
There must be some problem.... here is a useful tip:
I often don't use "Add to cart from recordset" even when I am doing a dynamic add to cart.
If you create a static add to cart button, you can create and filter your own recordsets and still refer to them as cart values. That way you can filter your recordsets how you want and have data that comes from more than one recordset after adding to the cart.
In your case I really couldn't tell you what was wrong without looking at it. Most likely the trigger for the add to cart is wrong somehow... maybe it was referring to the button name and your button names have changed.
