upload to database
Thread began 5/19/2009 10:26 am by george50130 | Last modified 5/20/2009 1:10 pm by Ray Borduin | 4388 views | 11 replies |
george50130
upload to database
OK I'm making decent progress with my admin area.
I used DataAssist to create all my product page tools.
I then replaced the textfields for my product images with a file upload field of the same name and went through the digital upload settings and came across to errors (thankfully as DW was crashing last night.
I then changed the productImage detail page to display an image rather than text. Looking at the source code displayed on the prod detail page it shows:
<img src="forming-cream.jpg" />
however, the path is incorrect. How can I rectify it?
Thanks in advance,
G
What is the correct path? Just go in and add the folder before the database reference so that the path will be correct.
george50130
the correct path should be /images/products/large/forming-cream.jpg
Although I've just noticed that the file isn't actually in place at all.
Code looks like so:
<?php require_once("../Connections/connHCHQ.php"); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
<?php require_once('../Connections/connHCHQ.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$maxRows_WADADynListproductbrand = 1000;
$pageNum_WADADynListproductbrand = 0;
if (isset($_GET['pageNum_WADADynListproductbrand'])) {
$pageNum_WADADynListproductbrand = $_GET['pageNum_WADADynListproductbrand'];
$startRow_WADADynListproductbrand = $pageNum_WADADynListproductbrand * $maxRows_WADADynListproductbrand;
mysql_select_db($database_connHCHQ, $connHCHQ);
$query_WADADynListproductbrand = "SELECT brandID, brandName FROM productbrand ORDER BY brandName";
$query_limit_WADADynListproductbrand = sprintf("%s LIMIT %d, %d", $query_WADADynListproductbrand, $startRow_WADADynListproductbrand, $maxRows_WADADynListproductbrand);
$WADADynListproductbrand = mysql_query($query_limit_WADADynListproductbrand, $connHCHQ) or die(mysql_error());
$row_WADADynListproductbrand = mysql_fetch_assoc($WADADynListproductbrand);
if (isset($_GET['totalRows_WADADynListproductbrand'])) {
$totalRows_WADADynListproductbrand = $_GET['totalRows_WADADynListproductbrand'];
} else {
$all_WADADynListproductbrand = mysql_query($query_WADADynListproductbrand);
$totalRows_WADADynListproductbrand = mysql_num_rows($all_WADADynListproductbrand);
$totalPages_WADADynListproductbrand = ceil($totalRows_WADADynListproductbrand/$maxRows_WADADynListproductbrand)-1;
$maxRows_WADADynListprodcategory = 1000;
$pageNum_WADADynListprodcategory = 0;
if (isset($_GET['pageNum_WADADynListprodcategory'])) {
$pageNum_WADADynListprodcategory = $_GET['pageNum_WADADynListprodcategory'];
$startRow_WADADynListprodcategory = $pageNum_WADADynListprodcategory * $maxRows_WADADynListprodcategory;
$query_WADADynListprodcategory = "SELECT CatID, CatName FROM prodcategory ORDER BY CatName";
$query_limit_WADADynListprodcategory = sprintf("%s LIMIT %d, %d", $query_WADADynListprodcategory, $startRow_WADADynListprodcategory, $maxRows_WADADynListprodcategory);
$WADADynListprodcategory = mysql_query($query_limit_WADADynListprodcategory, $connHCHQ) or die(mysql_error());
$row_WADADynListprodcategory = mysql_fetch_assoc($WADADynListprodcategory);
if (isset($_GET['totalRows_WADADynListprodcategory'])) {
$totalRows_WADADynListprodcategory = $_GET['totalRows_WADADynListprodcategory'];
} else {
$all_WADADynListprodcategory = mysql_query($query_WADADynListprodcategory);
$totalRows_WADADynListprodcategory = mysql_num_rows($all_WADADynListprodcategory);
$totalPages_WADADynListprodcategory = ceil($totalRows_WADADynListprodcategory/$maxRows_WADADynListprodcategory)-1;?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../images/products/large/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "../images/products/thumbs/",
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "ProdImage", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "ProdThumb", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult2_Params);
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $connHCHQ;
$WA_table = "products";
$WA_sessionName = "WADA_Insert_products";
$WA_redirectURL = "products_Detail.php";
$WA_keepQueryString = false;
$WA_indexField = "ProdID";
$WA_fieldNamesStr = "ProdID|ProdBrandID|ProdName|ProdShortDesc|ProdLongDesc|ProdKeywords|ProdPrice|ProdRRP|ProdSKU|ProdThumb|ProdThumbAlt|ProdImage|ProdImageAlt|ProdCatID|ProdIsFeatured|ProdIsActive|ProdStockAvailability";
$WA_fieldValuesStr = "".((isset($_POST["ProdID"]))?$_POST["ProdID"]:"") ."" . "|" . "".((isset($_POST["ProdBrandID"]))?$_POST["ProdBrandID"]:"") ."" . "|" . "".((isset($_POST["ProdName"]))?$_POST["ProdName"]:"") ."" . "|" . "".((isset($_POST["ProdShortDesc"]))?$_POST["ProdShortDesc"]:"") ."" . "|" . "".((isset($_POST["ProdLongDesc"]))?$_POST["ProdLongDesc"]:"") ."" . "|" . "".((isset($_POST["ProdKeywords"]))?$_POST["ProdKeywords"]:"") ."" . "|" . "".((isset($_POST["ProdPrice"]))?$_POST["ProdPrice"]:"") ."" . "|" . "".((isset($_POST["ProdRRP"]))?$_POST["ProdRRP"]:"") ."" . "|" . "".((isset($_POST["ProdSKU"]))?$_POST["ProdSKU"]:"") ."" . "|" . "".((isset($_POST["ProdThumb"]))?$_POST["ProdThumb"]:"") ."" . "|" . "".((isset($_POST["ProdThumbAlt"]))?$_POST["ProdThumbAlt"]:"") ."" . "|" . "".((isset($_POST["ProdImage"]))?$_POST["ProdImage"]:"") ."" . "|" . "".((isset($_POST["ProdImageAlt"]))?$_POST["ProdImageAlt"]:"") ."" . "|" . "".((isset($_POST["ProdCatID"]))?$_POST["ProdCatID"]:"") ."" . "|" . "".((isset($_POST["ProdIsFeatured"]))?$_POST["ProdIsFeatured"]:"") ."" . "|" . "".((isset($_POST["ProdIsActive"]))?$_POST["ProdIsActive"]:"") ."" . "|" . "".((isset($_POST["ProdStockAvailability"]))?$_POST["ProdStockAvailability"]:"") ."";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL|',none,''|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL";
$WA_connectionDB = $database_connHCHQ;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
{my html is in here}
mysql_free_result($WADADynListproductbrand);
mysql_free_result($WADADynListprodcategory);
Not sure if you can control the forum Ray but the code highlighting functionality would be a great addition in these forums.
george50130
Followed this 05_upload_insert.swf to the letter and still no joy
you currently have:
<img src="<?php echo($row_RSName['ImageField']); ?>" />
change it to:
<img src="/images/products/large/<?php echo($row_RSName['ImageField']); ?>" />
Then the path will appear correct.
Next you can work on why the image isn't uploading.
george50130
Thanks Ray - managed to get it sorted.
Actually sorted the upload first and then the display.
I remembered that my image wasn't actually uploaded to the database but the path to the database and the physical file in a directory.
george50130
can you point me in the direction of the next part of 05_upload_insert.swf
Not sure what you mean by the next part. What are you trying to do? What happens when you try?
george50130
it's the update record part that the last few moments of that tutorial mentions.
What is confusing about it? What have you tried? Where exactly do you get stuck? What is unclear?
