multiple marker styles one map
Thread began 3/15/2010 2:09 pm by cgschn380661 | Last modified 3/15/2010 5:43 pm by cgschn380661 | 725 views | 2 replies |
cgschn380661
How (and where) can I code for certain records to have one marker style (balloon) and others to have another style (push-pin)? I am revisiting a successful map, attempting to add another type of data. I am new to php, but I can find my way around if instructed in detail.
Thank you for replies.
Jimmy Wu
In the google_javascript/wagmp_map_[mapnum].php file, you would want to find the code that looks like this:
var icon_0 = new GIcon();
icon_0.image = 'plugins/google_javascript/images/traditionalflat_pacifica.png';
icon_0.shadow = 'google_javascript/images/traditionalflat_shadow.png';
icon_0.iconSize = new GSize(34,35);
icon_0.shadowSize = new GSize(34,35);
icon_0.iconAnchor = new GPoint(9,33);
icon_0.infoWindowAnchor = new GPoint(19,0);
icon_0.printImage = 'plugins/google_javascript/images/traditionalflat_pacifica.gif';
icon_0.mozPrintImage = 'plugins/google_javascript/images/traditionalflat_pacifica_mozprint.png';
icon_0.printShadow = 'google_javascript/images/traditionalflat_shadow.gif';
icon_0.transparent = 'google_javascript/images/traditionalflat_pacifica_transparent.png';
For each of the points, there will be another block of code that looks like that but with a different icon_[num]. You would want to change the icon here and make sure you have the images stored in the google_javascript/images directory.
cgschn380661
2 sets of points & markers
I'm glad it's possible. Now for the execution. Currently, the map has one pull-down menu, which calls the data points by county. I think what I'm being asked to do is create a second pull-down menu, to access other lat/long data points by watershed/region. Data from the 2 pull-down menus will display with 2 styles of markers. Data from both pull-down menus should display data on the same map.
Keeping in mind I'm brand-new at php code, how do I go about
1) setting-up markers that correspond with the items in one menu versus the other, and
2) ensuring that a user's choices from both pull-down menus are displayed simultaneously
Thank you!
In case it helps, the site is at eagleData.php but you need to register/login to view.
