Insert Date Problem
I have set up a simple mysql DB with 2 fields, Name and Date (I have used DATE in MySQL). I then have used Dataassist to create insert, detail and report pages. When I post a date on insert page using 30-04-2010 it just displays 0000-00-00 on the detail page. I am new to database, PHP and MySQL. Can anyone point me in the direction of what I am doing wrong?
Thanks for any help in advance?
Fabian
The code of insert page is:
<?php require_once('Connections/connDate.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $connDate;
$WA_table = "datetestTbl";
$WA_sessionName = "WADA_Insert_datetestTbl";
$WA_redirectURL = "datetestTbl_Detail.php";
$WA_keepQueryString = false;
$WA_indexField = "id";
$WA_fieldNamesStr = "id|Date|Name";
$WA_fieldValuesStr = "".((isset($_POST["id"]))?$_POST["id"]:"") ."" . "|" . "".((isset($_POST["Date"]))?$_POST["Date"]:"") ."" . "|" . "".((isset($_POST["Name"]))?$_POST["Name"]:"") ."";
$WA_columnTypesStr = "none,none,NULL|',none,NULL|',none,''";
$WA_connectionDB = $database_connDate;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Insert datetestTbl</title>
<link href="WA_DataAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAInsertContainer">
<form action="datetestTbl_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<div class="WADAHorizLine"><img src="WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">Date:</th>
<td class="WADADataTableCell"><input type="text" name="Date" id="Date" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Name:</th>
<td class="WADADataTableCell"><input type="text" name="Name" id="Name" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="datetestTbl_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</body>
</html>
