safari community toolbar error
I am getting an error message every time I attempt to make a change with CSS sculptor.
"this version of safari does not support the community toolbar"
I am clueless...
I am clueless...
I am using version 3 of css sculptor
ok, figured it out. Some type of plugin had been downloaded...
uninstall and poof. no more error
Great to hear you were able to resolve the error. If you run into any additional issues, feel free to open a new thread.
I get the same error message, when launching Sheepshaver, or when Backup starts up. How did you get rid of it?
It looks like the user resolved this by uninstalling some plugins that were installed on their safari.
He doesn't actually say Safari, he may have been talking about CSS Sculptor or Dreamweaver.
I attach a list of my Safari plugins. There are many, but they all seem to be collected under a few reputable and unrelated categories and certainly nothing obvious like "Community Toolbar". Or do you see something suspicious?
I'm not sure I mentioned, but there is a Sheepshaver icon in the error dialog.
I vaguely recall that Vuze may have had a Community Toolbar thing it wanted to install. But when I use the 'uninstall plugins' command in Vuze, there were only 4, apparently unrelated plugins.
None of the plugins jump out at me immediately as problem causing, but that seems to be the issue. Try going into preferences->security and disabling plugins and see if that resolves the issue. If it does, that means one of your plugins is causing the issue.
That was a logical experiment. I tried it. I disabled plugins in Safari, then quit and relaunched Sheepshaver. I still got the same complaint.
So, as I suspected, this mystery toolbar is not located in the Safari plugins. But where?
It seems like this might be an issue with the sheepshaver program itself. Try contacting sheepshaver support and seeing if they have anything that would help you with the error:
sheepshaver.cebix.net/
