White label / Rebrand PowerGallery
Thread began 3/02/2010 5:52 am by PimpMyHoodie | Last modified 3/05/2010 3:46 pm by Ray Borduin | 2372 views | 8 replies |
PimpMyHoodie
Please help this is driving me mad!...
I know enough about dreamweaver but am not a total expert, I have followed certain tutorials that I have found but things keep going wrong!!..
Basically, within the "admin" section I'm trying to completely clear out all of the Webassist:
1. PowerGallery™ references
2. PowerGallery & Webasisst logos
3. Page footers with html links to webassist
4. links to webassist (such as the Feedback links)
And anything else that will give the game away to a client that this is simply a pre-built php solution and not built from scratch!..
I've tried updating the templates and then applying the templates to all of the pages, it seems to work but then it simply stops all of the: "Manage Images" & "Add Images" functionality from working!!..
p.s.
I can remove / replace the .png images in fireworks, that's easy enough to do, but my real problem is changing all of the items on the .php pages (as mentioned above!) without messing everything up!!..
please help, asap..
If someone could provide me with a clear and simple set of instruction of how to do this in Dreamweaver CS4 I would be eternally grateful!!..
(this is the last thing I need to do to the site, and the client is expecting a site from me (not webassist!.. lol) by tomorrow!..
thankyou, and sorry for being a (dare I say it!) Noooooooob!.. ;-)
p.s.
If someone from webassist sees this:
Please don't take this the wrong way, but I though these solutions were supposed to be " White Label "? It just seems to me that you've taken every opportunity to add links and references back to webassist.. Fair enough if it's a labeled product, but not if I'm trying to pass pre-built applications off as part of my own work!
(that's face it that's why developers use your products isn't it??!!)
I don't mean this to be aggressive, just making a point.. If I (or any other developer) misses on small link (such a the "Feedback" > "Webassist" link in powergallery admin, or all of the PowerGallery™ references in the help pages!) it could mean a whole world of trouble if a client finds out you've charged them "X" amount of $ for a pre-built php solution that only cost you $100 or so...
thankyou again, and I hope you find this constructive, and perhaps can provide an answer!.. ;-)
Office Guy-172461
Good points. Fits in well with this discussion:
showthread.php?t=10658
It makes it appear that WA is moving away from the developer market. Why else would there be so many attempts to point people back to WA? At the very least there should be a warning that it's not intended for reselling. It makes sense in Open Source solutions but usually you can pay a small fee to remove the links back to the developer. This is a paid solution and they're embedded into the product. Why should we have to spend our time hunting them down?
PimpMyHoodie
very interesting...
Hi Office guy, thanks for the link, it's makes very interesting reading, and I think I'm going to post there myself!.. but in the mean time, do you think you could help me out with the problem of rebranding as listed above?. (I'm getting a bit stressed now!.. :-S )
Office Guy-172461
Not sure I can. Using this method:
Find all instances of a variable in a site
185/
I came up with:
340 items for powergallery
195 items for webassist
Some of those might be from other extensions but it's not a straightforward task.
The links were added in an attempt to improve our search engine rankings, not as an attempt to advertise to your clients. This was a side effect that people have now pointed out is worrisome and we will look into.
I'd bet that most of those are repeats because the page is based on a template. I think if you were to scrub three pages of links it would probably do the trick:
The Templates Main.dwt.php and Admin.dwt.php, and the index.php page.
Those are really the only three page layouts used throughout the site. Links that appear on the template pages are propogated to each page, so will appear many times on the site even though they only have to be removed once and then you can update the pages that are created from the templates to remove all occurrances.
PimpMyHoodie
simpler...
Hi, thanks for the reply..
I too have done a similar search by opening one of the powergallery admin php pages (in my case addimages.php) using dreamweaver's "find and replace" function..
Accept, all I did was:
find in: "Current Document"
Search: "text"
Find: "PowerGallery"
and found just 2x instances....
In this instance I'm not bothered about the code and/or anything else that is hidden from the layman (joe public admin)...
To give an example the site I'm currently working on is for a female yoga instructor, who doesn't know the first thing about websites and code (why would she?), so all I need to do is remove anything that is visible to the "naked eye" of just a basic "Admin" user...
Like the thread you linked me to above suggests if the Admin user sees "POWERGALLERY™ ADMIN" it's not going to be hard to Google PowerGallery, find out what it is, how much it costs, and feel ripped off... (If I saw "POWERGALLERY™ ADMIN" in my new website googling it would be the first thing I would do!)
But, my average admin user is not going to be looking at code and other "hidden" parts of the site pages.
So, back to the point..
When I click "Find & Replace" in dreamweaver I get this message:
"The following replacements would have changed a locked region of a file that uses a template"
Now I know this is a really dumb question, but I'm self taught and am still trying to figure it all out, all I actually want to do is, unlock the locked regions in the template and update them all so that I can replace the basic visible text...
i.e.
I want to replace "POWERGALLERY™ ADMIN" with "MY YOGA SITE ADMIN" but can't do it because it's locked by the template, and I can't update the template without messing up the functionality of the .php page (as described in my first post)..
I'm pretty sure the answer is simple, and I'm going to feel silly when I know how.. but at the moment, I don't know how!.. lol!..
please help!..
(anyone!)
Thankyou!.. ;-)
PimpMyHoodie
Update pages..
Hi Ray,
Thankyou for your reply...
I already have updated the following files:
"The Templates Main.dwt.php and Admin.dwt.php, and the index.php page. "
And uploaded them to the server....
but it doesn't seem to propagate all of the pages,
All I'm doing is opening, editing, and then saving...
Is it because I'm not updating all of the pages created from the templates?..
(I don't getting a message asking me if I'd like to "update all of the pages created from this template", and I'm guessing I should right?)
Can you tell me how to do this correctly?..
Thanks.
Roland Rogers
I was able to do a full stripping of the WebAssist code to brand it as a custom gallery by adjusting the templates. I don't have time right now to document everything I did but just wanted to do a quick reply to assure folks that it can be done pretty easily!
I further pimped the gallery for a client to allow for multiple galleries to appear on one page and the visitor can select which gallery to view.
gallery.php
It was a bit of work but the client loves it - and the admin is custom branded with no link back to WebAssist.
Most likely the problem is that you don't have your dreamweaver site set up with the Templates folder in the root.
Dreamweaver will only scan and update all of the files if the Templates folder is in the root.
Just set up a new DW site and declare the root as the directory where the Templates folder exists. Then when you update the template in DW it will ask you if you want to update all of the pages.
