Power Gallery not working for me
Thread began 2/13/2010 3:33 pm by e394610 | Last modified 3/01/2010 11:30 pm by Dani Chankhour | 5361 views | 16 replies |
e394610
[ORIGINAL MESSAGE] - SEE MY UPDATE AT THE END
Everything was successful during the installation, but when I added the php code into the page below it does not view properly. No photos, etc. All photos processed successfully during the installation.
photos
(If you click on this link while on the amused2death site you will be redirected to the main domain paattorneys with these photos. I would like the gallery to work on the amused2death domain)
This is the http: address the admin page provides:
AMUSED2DEATH...y=1&theme=dark
When clicking preview on the admin side:
galleries...y=1&theme=dark
It looks as if the photos are loading somewhat, but they do not show.
I am using firefox browser version 3.5.7, but have also tested using IE with similar results.
I am hosted at Godaddy, but with other domains on the same hosting plan.
Also, I can log into the Admin part of the site and view, add or edit photos.
I followed the directions and deleted the install folder following clicking next to go to the admin page. When I did that I would not get anything and was unable to log in to the admin page when this was done. When the install folder is kept I am able to log into the admin side as well as get something on the preview pages.
Any help would be appreciated.
Thanks,
Ernie
p.s. I posted this as a reply, but wasn't sure if it would be looked. I then thought I posted in a new thread last night, but when logging in today I did not see the new thread. I apologize if this is already in the queue, but want to make sure I get this resolved.
[UPDATE]
Ok, I tested this on the main domain name that my hosting account is under on godaddy.com. It works fine, but does anyone know a solution to make this work when using a subdomain on my hosting account as I would like this to work on amused2death.org?? Thank you.
Dani Chankhour
PowerGallery uses the absolute path, so as long as your sub domain is a sub folder of the main domain, then it should work, otherwise you will need to have a separate power gallery for your sub domain.
e394610
I am using the absolute path...see more detail below
Originally Said By: Dani Chankhour
That's how I have it set up. See description below
I use Godaddy.com hosting.
1. Main hosting account is called let's say "main.org"
When I upload the Power Galley files to the main hosting account "main.org" (in the html default folder) the install of the PG works. See below for the setup that works:
main.org
html
pg(this is where I put my power gallery files)
I then go to main.org/pg and go through the install steps the Power Gallery works.
2. Now when I activate another domain I have in my account on the same hosting plan and create a subfolder for that domain, i.e.:
main.org
html
amused2deathorg
I then go to main.org/amused2deathorg/pg and go through the install steps the Power Gallery does not work.
I am going to stop testing this and leave all information up where it is so you(webassist) can see what is happening b/c I have tried this many times with the same result. I have also tested on another subdomain to see if the specific domain amused2death.org was the culprit. I tested on amused2death.net as well which is where my files are active now. The links the admin section provides are below.
main link after clicking preview at the top of the admin page
index.php?gallery=1&theme=dark
Direct Link to Your Gallery
Embed in PHP Page
$pg_id = '1';
$pg_theme = 'dark';
include('/home/content/e/r/n/ern13/html/AMUSED2DEATHNET/pg/galleries/ribbon_fullsize/index.php');
If someone has had the same issue or if someone else can try it on a another domain on the same hosting account if they use godaddy.com to see if they can recreate the problem I am having and hopefully help me resolve this I would appreciate the help.
Thank you,
Ernie
Dani Chankhour
In your galleries folder, there is a global.php file, try replacing these lines of code:
$pg_config = array(
'path' => str_replace('galleries/', '', str_ireplace(str_ireplace('\\', '/', realpath($_SERVER['DOCUMENT_ROOT'])), '', $abs_prefix)),
'html_prefix' => str_ireplace(str_ireplace('\\', '/', realpath($_SERVER['DOCUMENT_ROOT'])), '', $abs_file) . '/'
to
$temp_path = str_replace('galleries/', '', str_ireplace(str_ireplace('\\', '/', realpath($_SERVER['DOCUMENT_ROOT'])), '', $abs_prefix));
$temp_path = substr($temp_path, strpos($temp_path,"/amused2deathorg"));
$temp_prefix = str_ireplace(str_ireplace('\\', '/', realpath($_SERVER['DOCUMENT_ROOT'])), '', $abs_file) . '/';
$temp_prefix = substr($temp_prefix, strpos($temp_prefix,"/amused2deathorg"));
$pg_config = array(
'path' => $temp_path,
'html_prefix' => $temp_prefix
e394610
No luck
Replaced code but no luck. Any other ideas? I am more than willing to provide any files or login info(temporarily) via email or PM for you to check if that is easier. I am no expert, but am learning quickly...especially with the help of webassist products.
I also tried it changing the amused2deathorg to all caps (AMUSED2DEATHORG) to see if it needed to be the exact way as it was spelled out on the hosting account.
Thanks,
Ernie
e394610
Here is the information for both domains on my hosting plan
Ok,
Attached is a text file with the coding and links for both the paattorneys.org domain and the amused2death.org domain. Again, both are on the same hosting plan. The paattorneys.org PG works, the amused2death.org does not work.
I went through the installation steps many times with the same results and I am at a stand still.
Any help and answer will be greatly appreciated. Thank for taking the time to look at my issue everyone.
Ernie
p.s. Let me know if you require additional information to resolve this matter.
A2D.txt
global.zip
index.zip
paattorneysglobal.zip
paattorneysindex.zip
Dani Chankhour
I have opened a support ticket to further assist you with this issue:
e394610
Resolved
Thanks to Dani the issue is now resolved.
Check the photos page out.
photos
e394610
Hate to be a pain in the butt...but another issue was created after the fix.
Dani,
Thank you for resolving the viewing issue I was having. After the fix I noticed on the admin side is now not allowing me to make any changes on the manage images tab. It does not allow me to change or update the name or add a description.
If you could, please look into this matter too?
[UPDATE]
I tried this with no luck:
showthread.php?t=10111
I replaced my code back to the original
Thanks,
Ernie
Dani Chankhour
Are you still having an issue after reverting back your changes?
