While executing onClick in SecurityAssistWizard, a javaScript error occurred.
Thread begun 10/08/2009 3:50 am by jegoadby285710 | Last modified 1/14/2011 12:30 pm by peterbroekman35409717 | 9262 views | 8 replies |
jegoadby285710
I get this error when tying to use Security Assist Wizard on a new php page it aslo does the same on pages i'ev ran it on in the past. I've uninstaled it and downloded a newer copy but still get the same arror. No new upgrades have been made to the Mac.
Im running a Mac on 10.5.8 and CS3 Dreamwever.
Its a real pain!
I have attached an image of the error
David StringerBeta Tester
Have you tried deleting your WinFileCache.dat in the Dreamweaver Configuration before opening up the programme? I'm not sure where it is situated on a Mac, but if you do a search of the forum I'm sure its there.
I've done what you've done occasionally, re-installing the extension. When I've done a new install I always delete the cache and this seems to help in most cases.
HTH
jegoadby285710
WinFileCache.dat O SX Mac
WinFileCache.dat. is MacFileCache-########.dat on a Mac
Location
Mac OSX;
-DW8
--Hard disk: Users: <Your User Name>: Library: Application Support: Macromedia: Dreamweaver 8:Configuration
-DWCS3
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver 9: Configuration
-DWCS4
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS4: en_US: Configurationion
jegoadby285710
This seems to be the problem (SecurityAssist_Object.js)
Still no good. Seems to be a problem with this file:
But if you remove this it definatly will not work.
Help
I'm sure that if you use the above to remove the MacFileCache, it should work for you.
Make sure you are deleting the macfilecache .dat file with Dreamweaver closed. 90% of the time that is the cause of errors like this.
If it still doesn't work, post back and I'll open a support incident so that someone can investigate this with you further.
jegoadby285710
Still not right
Unfortunately its not making any difference, I even put the Mac though a restart.
I have created a support incident so that we can look into this with you further over the phone. Make sure to update your incident with contact information.
While executing Onload - annoying Security assist wizard error
There are two or three therads with the same issue. When opening the secuty assist wizard I only get this: While executing onLoad in SecurityAssistWizard.htm, the following Javascript errors(s) occured: At line 258 ......:Commands:SecurityAssistWizard.js. I see a pop-up after cancelling that's totally gray. There are back and next buttons when pushed the give the same mistake on lines 748 and 798 of another javascript file SecurityAssist_Object.js.
Deleting the .dat cache file does not help, nor does uinstalling. I am on a Macpro and a bit frustrated. This part is one of the main reasons I bought the whole package. Really need it. Please do some more testing whatsoever, this must be a mistake that happens more often (it does since it's in this formum).
