DB updater page in html editor
Thread begun 3/09/2013 8:15 am by Patrice | Last modified 3/05/2014 9:33 am by Patrice | 8507 views | 37 replies |
PatriceWebAssist
I am seeing a new, odd error.
Upon loading the update page, in the html editor, in source code, this line is popping up:
(see screen shot)
This results in an A symbol in the copy. I erase it, it pops up on another spot, at the end of a paragraph, so some return is affecting it, I'm guessing.
Have you seen this before?
on the update page, look for the following line:
$CKEditor_config["entities"] = true;
and change it to;
$CKEditor_config["entities"] = false;
PatriceWebAssist
Thanks so much Jason. I'll take a look.
PatriceWebAssist
on the name_updater.php page or in the webassist/ckeditor area?
I did a search on name_updater.php and didn't spot a similar line
PatriceWebAssist
// The initial value to be displayed in the editor.
$CKEditor_initialValue = "".((isset($_GET["invalid"])?ValidatedField("pagecopyupdate","pc_content",false):"".$row_WADApagecopy["pc_content"]."")) ."";
$CKEditor = new CKEditor();
$CKEditor->basePath = "../webassist/ckeditor/";
$CKEditor_config = array();
$CKEditor_config["wa_preset_name"] = "no word paste";
$CKEditor_config["wa_preset_file"] = "nowordpaste.xml";
$CKEditor_config["width"] = "500px";
$CKEditor_config["height"] = "500px";
$CKEditor_config["skin"] = "kama";
$CKEditor_config["docType"] = "<" ."!" ."DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01 Transitional//EN\" \"http://www.w3.org/TR/html4/loose.dtd\">";
$CKEditor_config["contentsLanguage"] = "";
$CKEditor_config["dialog_startupFocusTab"] = false;
$CKEditor_config["fullPage"] = false;
$CKEditor_config["tabSpaces"] = 4;
$CKEditor_config["toolbar"] = array(
array( 'Source','-','Save','NewPage','Preview','-','Templates'),
array( 'Cut','Copy','Paste','PasteText','-','Print','SpellChecker','Scayt'),
array( 'Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'),
array( 'Form','Checkbox','Radio','TextField','Textarea','Select','Button','ImageButton','HiddenField'),
array( 'BidiLtr','BidiRtl'),
array( 'Bold','Italic','Underline','Strike','-','Subscript','Superscript'),
array( 'NumberedList','BulletedList','-','Outdent','Indent','Blockquote','CreateDiv'),
array( 'JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'),
array( 'Link','Unlink','Anchor'),
array( 'Image','Flash','Table','HorizontalRule','Smiley','SpecialChar','PageBreak'),
array( 'Styles','Format','Font','FontSize'),
array( 'TextColor','BGColor'),
array( 'Maximize','ShowBlocks','-','About'));
$CKEditor_config["contentsLangDirection"] = "ltr";
$CKEditor_config["pasteFromWordRemoveFontStyles"] = false;
$CKEditor_config["pasteFromWordRemoveStyles"] = false;
$CKEditor->editor("pc_content", $CKEditor_initialValue, $CKEditor_config);
PatriceWebAssist
I saw it but it is false
and change it to;
PatriceWebAssist
More information: this is my standard default set up and it is the first time it has shown up after many sites, etc.
So it is set to false, but as soon as I add a new page, it crops up. When I edit an existing page is SOMETIMES crops up. No consistency on this new site.
If I set up a page in myphp admin first, not showing up. If I add a new page within WA "insert" it is cropping up.
PatriceWebAssist
I created a new fresh admin and did further testing. It only happens when my client was copying text from another source. I had turned off the copy paste feature from Word, but evidently that doesn't keep the code clean from other copy pastes. I closed the ticket. Thanks for starting it for me.
PatriceWebAssist
It's back again... New site. No client copy paste at all. If I leave an html editor box blank it enters the A symbol code each time.
I am using this
fd_cool_default.xml
<?xml version="1.0" encoding="utf-8"?>
fd_cool_default.css
@charset "utf-8";
Any ideas, most appreciated.
