Security Issue - Server Asset Folder
Thread begun 8/26/2011 1:40 am by contactus306424 | Last modified 9/19/2011 8:21 am by Dave Buchholz | 6170 views | 8 replies |
contactus306424
Are you aware that direct unsecure access can be made to the server asset area using the following URL (cms is the PowerCMS folder), you don't need a username or password to gain access.
index.php?lang=default&kfm_caller_type=fck&type=Image
Anyone else concerned about this?
This is fixed in Power CMS 2.1.1.
to fix it in earlier version. edit the HTMLEditor/editor/plugins/kfm/configuration.php file. change:
<?php require_once( "../../../../Connections/PowerCMSConnection.php" ); ?>
require_once( "../../../WA_Globals.php" ); ?>
to:
require_once( "../../../../WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("Administrator")){
    die();
contactus306424
Great, thanks for your assistance...
contactus306424
I get the following Errors with that modification
Warning: Cannot modify header information - headers already sent by (output started at /home/vanguard/public_html/cmscontrol/HTMLEditor/editor/plugins/kfm/configuration.php:4) in /home/vanguard/public_html/cmscontrol/HTMLEditor/editor/plugins/kfm/includes/session.class.php on line 31
Warning: Cannot modify header information - headers already sent by (output started at /home/vanguard/public_html/cmscontrol/HTMLEditor/editor/plugins/kfm/configuration.php:4) in /home/vanguard/public_html/cmscontrol/HTMLEditor/editor/plugins/kfm/index.php on line 73
It looks like you might have an extra space character on line 4 of /HTMLEditor/editor/plugins/kfm/configuration.php.
That is just a guess... If you attach a copy of that page I can look into it further.
contactus306424
Thanks ray, you are correct there was an extra space in there, all working fine now...
msummers194171
It appears that I have the same exploit going on my PowerStore site. But my configuration.php file has this content -
<?php require_once( "../../../../Connections/PowerStoreConnection.php" ); ?>
<?php require_once( "../../../../webassist/framework/library.php" ); ?>
* KFM - Kae's File Manager
How should I implement this fix?
There is a fix for this available in the Known Issues section of the Power Store download center page.
Dave BuchholzBeta Tester
Jason, surely the fact that the fix is available should be publicised, I have a number of clients who have been affected by this issue and none of them were aware of this fix.
