Getting close but still have an error message
Thread begun 7/21/2011 11:34 pm by genelee2330761 | Last modified 7/22/2011 11:06 am by genelee2330761 | 4885 views | 9 replies |
genelee2330761
I finally got all the Security assist generated pages going the way they should but when I try to protect a page with a login I get the following error mesage after logging in and trying to view the protected page:
Fatal error: Cannot redeclare wa_authenticateuser() (previously declared in /homepages/46/d366494719/htdocs/webcom/webassist/security_assist/helper_php.php:28) in /homepages/46/d366494719/htdocs/webcom/WA_SecurityAssist/Helper_PHP.php on line 48
Mike Perry
Originally Said By: genelee2330761
Just guessing -- do you have duplicate SA behaviors on the page? Do you have an SA Authenticate server behavior on the protected page (not the Login page)?
It appears you have the old and new version of the security assist include file on the page.
Delete the reference to: /WA_SecurityAssist/Helper_PHP.php
The new file: /webassist/security_assist/helper_php.php
Has replaced the old one so that the old one is no longer necessary and will cause this error if both appear on the page.
genelee2330761
On the page I am trying to view (the protected page) I find a reference to the new file (/webassist/security_assist/helper_php.php) but not to the old one.
Is there somewhere else I should be looking for this call to the older file?
genelee2330761
One thing that I just thought of is that this started after I added CSM to the page using Power CMS Builder. Could this have put in a reference to the older file?
It has to be either on the page or on one of the pages included on the page. Can you send me a copy of the page and I'll take a look.
genelee2330761
Here is a copy of the protected page.
I have been looking at other pages that I thought might be being accessed and found a reference to the old security file in one of the files in the admin_cms folder. Could this be where the problem is coming from since I set up the CMS after the security was in place?
genelee2330761
Actually, as I keep looking the reference to the old file seems to be all over in the files generated by Power CMS Builder
It is the one referenced in WA_CMS/WA_CMS.php that is causing the issue. You can probably just update the path there to point to the new location. The other ones shouldn't cause any issues since they are on other pages.
genelee2330761
That got it.
Thanks Ray
