Problem uploading images
Thread begun 9/23/2010 3:28 pm by mick106153 | Last modified 10/04/2010 12:09 pm by Jason Byrnes | 8127 views | 21 replies |
mick106153
I'm having difficulty uploading images - actually not. The images upload but PowerStore will not recognize them.
Checking assigned permissions shows that the latest images I've uploaded have
rw- r-- --- or 0640
previous images are all
rw- rw- r-- or 0664
or
rw- r-- r-- or 0644
Is it PowerStore,
or is it NetworkSolutions?
Mick
mick106153
I'm thinking it's because I'm grabbing them off a network drive. Am now attempting to access those permissions.
Also. Is there a way when linking to images in PowerStore that we can link to files that already exist in the "imagesupload" folder that PowerStore creates?
Seems to me that that could save a lot of time and frustration.
Looking in there I see iteration after iteration of the same file appended with -1, -2, -3 etc. because of my repeated attempts to upload the same image.
Barring that, a folder at that same level I can put the images in than allow PowerStore to work its magic before putting the images in its proprietary folder.
Mick
mick106153
Further investigation reveals that placing the images on my local hard drive prior to upload eliminates the problem.
I would prefer that not be the case.
Another day perhaps.
Mick
on the product insert page, the code to upload the image is:
WA_DFP_SetupUploadStatusStruct
("WA_UploadResult1");
if(
$_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1""ProductImage""2""[NewFileName]_[Increment]""true"$WA_UploadResult1_Params);
("WA_UploadResult2");
if(
WA_DFP_UploadFiles("WA_UploadResult2""ProductThumb""2""[NewFileName]_[Increment]""true"$WA_UploadResult2_Params);
you could add the chmod function to change the files permisions after it is uploaded:
if(
chmod($WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]."".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"], 0644);
if(
chmod($WA_DFP_UploadStatus["WA_UploadResult2"]["serverDirectory"]."".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"], 0644);
mick106153
Jason thanks and another question.
Thanks Jason
That looks like it should work.
But I have another question you may want to move to a new thread.
Moving PowerStore to a different server.
I talked to my hosting service about the slowness of the performance of the PowerStore admin - uploading and updating products etc. - and was told that because I'm on a shared server and only allocated 32meg ram I will have problems.
I recently secured a VPS with 512meg which should address that problem but I don't know what I need to do to safely port everything there and get it functional.
Addresses will change and the connection to the server will be different. And I'm guessing that I need to do the install procedure to get PowerStore running.
Can you tell me what I need to do to make this happen without having to build everything over again?
And would upgrading to PowerStore 4 (I'm at 3) make this process any easier?
Mick
Power Store 4 will not make this any simpler.
You will need to backup the power store database, then import it to the new server.
Then update the Website URL in the wa_settings table.
you may also need to edit the local root and remote root settings.
Then edit the connection file to use the new mySQL server.
mick106153
Since my last response I've upgraded to PS4, moved all the images to my local drive, changed their permissions to 664 and the problem hasn't changed.
I spoke to my host and image uploads all come in as 664 according to their settings.
But, for me, they arrive there as 640 and changing them to 664 after the fact doesn't work.
The section of code you indicated previously has changed in PS4 so how about a revised update and am I the only person with this problem?
Is it possible that it has anything to do with case? My images are mixed case.
Mick
P.S. And why oh why can't I chose images that are already on the server as is done in the image gallery? That just makes no sense.
mick106153
Jason
Just read this:
"The only folders we create and set permissions on are the imagesupload, webassist, and Connections folders. We specifically set them to 777 in order to allow the editor and file uploads to work properly when editing."
Here: showthread.php?t=16228
The "imagesupload" is the folder that's causing me grief.
Talked to NS and they set everything to 664 on upload and apparently can't or won't make a change.
So I'm guessing that that's the source of the problem.
He assured me that a script - like the one you devised earlier - would work.
Mick
on the admin/products_insert.php page, change this code block to:
if(
WA_DFP_UploadFiles("WA_UploadResult1""ProductThumb""2""[NewFileName]_[Increment]""true"$WA_UploadResult1_Params);
if(
WA_DFP_UploadFiles("WA_UploadResult2""ProductDigitalFile""2""[NewFileName]_[Increment]""false"$WA_UploadResult2_Params);
to:
if(
chmod($WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"], 0644);
if(
chmod($WA_DFP_UploadStatus["WA_UploadResult2"]["serverDirectory"], 0644);
and this code block"
("WA_UploadResult3");
if(
WA_DFP_UploadFiles("WA_UploadResult3""ProductImage""2""[NewFileName]_[Increment]""true"$WA_UploadResult3_Params);
to:
if(
chmod($WA_DFP_UploadStatus["WA_UploadResult3"]["serverDirectory"], 0644);
chmod($WA_DFP_UploadStatus["WA_UploadResult3"]["serverDirectory"]."".$WA_DFP_UploadStatus["WA_UploadResult3"]["serverFileName"], 0644);
mick106153
Jason thank you
Just made the change you recommended and it didn't work…
Not your fault though cause I've been using the product_update page not the product_insert page. Code looks similar but I'm not comfortable with attempting to make that change without some more input from you - please.
In the mean time I will upload a new product and give you feedback on whether the change to Product_insert.php works as expected.
Mick
