Known Issue for Universal Email 4: Using Pear Mail for SMTP
Thread begun 9/20/2010 11:41 am by Anna Robinson | Last modified 8/03/2012 12:33 pm by Base5 Designs | 12083 views | 7 replies |
Anna Robinson
There was a bug discovered in Universal Email 4 where PHP errors are generated when using Pear Mail for SMTP. We have created a patch if you are experiencing this.
Log in and visit the Download Center. Click on Universal Email 4; then click on the Known Issues section. Download the related zip file and follow the instructions in the readme file.
toms016390756
Where would I see the PHP error?
you would see the error on the page that Universal Email where applied to when it tries to send the email, but only if error reporting is turned on.
support16813
UE4 - PEAR for SMTP patch file
The patch to replace the XML file for PEAR for SMTP -- refers to Windows XP & VISTA operating systems.
Is this patch also required on Windows 7 systems?
yes, it is also needed for windows 7.
the path to use in windows 7 is the same path as in Vista.
Base5 Designs
This post has been deleted.
Base5 Designs
i ahve universal email 4 in the dataassist and databridge packages, so am unable to access this fix.....
my error on the php page is as follows:
PHP Warning: Missing argument 7 for WA_MAILOBJ::WA_MAILOBJ(), called in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 77 and defined in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 99 PHP Warning: Missing argument 8 for WA_MAILOBJ::WA_MAILOBJ(), called in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 77 and defined in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 99 PHP Warning: Missing argument 9 for WA_MAILOBJ::WA_MAILOBJ(), called in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 77 and defined in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 99 PHP Notice: Undefined variable: organization in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 108 PHP Notice: Undefined variable: xMailer in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 109 PHP Notice: Undefined variable: charSet in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 110 PHP Warning: require_once(.;D:\Parallels\Additional\PleskPHP5\pearMail.php) [function.require-once]: failed to open stream: Invalid argument in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 121 PHP Fatal error: require_once() [function.require]: Failed opening required '.;D:\Parallels\Additional\PleskPHP5\pearMail.php' (include_path='.;D:\Parallels\Additional\PleskPHP5\pear') in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 121
will the patch fix this???
You reported this in another thread as well, in that thread you reported that you had fixed the problem?
Base5 Designs
yeah i have, i had posted in here b4 i started the other thread, thanks is all sorted
