Search multiple fields
Thread begun 7/26/2010 11:00 am by robcorrick409194 | Last modified 8/05/2010 11:34 am by Jason Byrnes | 7325 views | 19 replies |
robcorrick409194
I have read several threads about searching multiple columns, but have not been successful. I would like to search more than one column from one input search field. I have set up a DataAssist search page with the wizard. The search function works well so far when I input a search parameter in a form fields set up by the Wizard. But it does not work with my new field. I have tried adding a behavior.
The first odd thing is that there is no dataset in the server behavior, but perhaps this is not necessary with the Search Form. So I created one. All of my columns show up nicely. I then add a set of queries. The setup looks like the images below. I am trying to to a search from S_UserCategories on three fields in my database: Category1, Category2, and Category3. When I click on Search, all of the records in the database are found, just as if no search parameter was entered, suggesting that I am not passing my parameter to the search function. Can you tell me how to do this correctly? Thanks. Great software so far.
Here is the code:
<?php require_once('Connections/localhost.php'); ?>
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: Recordset1;
//Searchpage: ;
//Form: ;
$WADbSearch1_DefaultWhere = "0=0";
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparison("Category1","".((isset($_GET["S_UserCategories"]))?$_GET["S_UserCategories"]:"") ."","AND","=",0);
$WADbSearch1->addComparison("Category2","".((isset($_GET["S_UserCategories"]))?$_GET["S_UserCategories"]:"") ."","AND","=",0);
$WADbSearch1->addComparison("Category3","".((isset($_GET["S_UserCategories"]))?$_GET["S_UserCategories"]:"") ."","AND","=",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_users_Search"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_users_Search"]) && $_SESSION["WADbSearch1_users_Search"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_users_Search"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereCla
the DataAssist search behavior should be applied to the Results page, make sure you are not applying the search behavior to the search page.
To create a search criteria that will search more than one database column from a single search input box,, change the search type from value to Keyword. This will allow you to select multiple columns to search.
robcorrick409194
Search Multiple fields. On Results page now.
Jason,
Thanks for telling me to put the search behaviors on the Results page and not the Search page. I have done this, as well as creating a key word behavior searching three columns per your suggestion. I am trying to do a multi-column search from one search field. I am still getting a blank result. In fact, when I create the new behavior, I get no search results from any field, so I am clearly doing something wrong.
Shots of the behavior windows are below. Please let me know if you need the code.
Is there something that I need to do to bind the new field in the Search form? I could not find anywhere to do this in the Server Behaviors related to the Search or Results pages.
Using DR CS5 Mac.
Bob
robcorrick409194
Changing search parameters
I am following up to my last thread, which has not be answered. Can someone please help me with this issue of changing my search parameters to include multiple fields. The standard functionality of Data Assist does not seem to have key word searches, and multiple field searches. Using the Wizard, I seem to be able to search only one field at a time. I almost have my website functional but for this big issue. It will be a great testimonial to the effectiveness of DA's extension software. Very impressive.
Can you please post a copy of the search and results page so I can examine the code.
robcorrick409194
Multiple Field Search
Jason,
I have used Data Assist Wizard to create the Results and Search pages. I have added about 15 fields to the Users Registration Profile, which makes up my primary database. These fields have been included in the Search page. I would now like to simplify the Search page by combining fields; that is, use one input search field to search in multiple columns in my database. In this example, I created a new input search field named S_Categories2, which I would like to query three fields: Category1, Category2, and Category 3. The coding for the Category1-2-3 search for the results page is below. The search page is in a following thread. (Eventually I would like also to have a key word search on all of the fields. )
My searches work fine using the fields created by the wizard. The search even works when I change from Edit mode to Value mode, and create a "Yes" filter on one of my fields. I receive a blank result, however, when I add the last key word query of Category1, 2 and 3.
I still wonder whether I should be binding the new filed somewhere, but I cannot seem to find anywhere to do this.
Thanks for you help.
RESULTS PAGE CODE:
//Recordset: WADAusers;
//Searchpage: users_Search.php;
//Form: WADASearchForm;
$WADbSearch1_DefaultWhere = "";
if ((isset($_GET["Search"]) && $_GET["Search"] != "")) {
$KeyArr1 = array("Category1", "Category2", "Category3");
$WADbSearch1->addComparisonFromEdit("UserCity","S_UserCity","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("UserState","S_UserState","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("UserCountry","S_UserCountry","AND","Includes",0);
$WADbSearch1->addComparison("Role","Yes","AND","=",0);
$WADbSearch1->addComparisonFromEdit("Role2","S_Role2","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("CareerSummary","S_CareerSummary","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Communications","S_Communications","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("AgePref","S_AgePref","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("LifeSummary","S_LifeSummary","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("PersonalExperience","S_PersonalExperience","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Category1","S_Category1","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Category2","S_Category2","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Category3","S_Category3","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("OrgType1","S_OrgType1","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("OrgType2","S_OrgType2","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("OrgType3","S_OrgType3","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("OrgTypesOther","S_OrgTypesOther","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("JobFunct1","S_JobFunct1","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("JobFunct2","S_JobFunct2","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("JobFunct3","S_JobFunct3","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("JobFunctOther","S_JobFunctOther","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("JobTitles","S_JobTitles","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Position1","S_Position1","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Position2","S_Position2","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Position3","S_Position3","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("MentorTopic1","S_MentorTopic1","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("MentorTopic2","S_MentorTopic2","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("MentorTopic3","S_MentorTopic3","AND","Includes",0);
$WADbSearch1->keywordComparison($KeyArr1,"S_Categories2","AND","=",",%20","%20","%22","%22",0);
if (1 == 1) {
$_SESSION["WADbSearch1_users_Results"]=$WADbSearch1->whereClause;
else {
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_users_Results"]) && $_SESSION["WADbSearch1_users_Results"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_users_Results"];
else {
else {
$WADbSearch1whereClause = '';
robcorrick409194
Search Page Multiple Fields
Search Page Code:
</div>
<div class="WADASearchContainer">
<form action="users_Results.php" method="get" name="WADASearchForm" id="WADASearchForm">
<div class="WADAHorizLine"><img src="WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">Search by Category</th>
<td class="WADADataTableCell"><input type="text" name="S_Categories2" id="S_Categories2" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">City</th>
<td class="WADADataTableCell"><input type="text" name="S_UserCity" id="S_UserCity" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">State</th>
<td class="WADADataTableCell"><input type="text" name="S_UserState" id="S_UserState" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Country:</th>
<td class="WADADataTableCell"><input type="text" name="S_UserCountry" id="S_UserCountry" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Role:</th>
<td class="WADADataTableCell"><input type="text" name="S_Role" id="S_Role" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Role2:</th>
<td class="WADADataTableCell"><input type="text" name="S_Role2" id="S_Role2" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">CareerSummary:</th>
<td class="WADADataTableCell"><input type="text" name="S_CareerSummary" id="S_CareerSummary" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Communications:</th>
<td class="WADADataTableCell"><input type="text" name="S_Communications" id="S_Communications" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">AgePref:</th>
<td class="WADADataTableCell"><input type="text" name="S_AgePref" id="S_AgePref" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">LifeSummary:</th>
<td class="WADADataTableCell"><input type="text" name="S_LifeSummary" id="S_LifeSummary" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">PersonalExperience:</th>
<td class="WADADataTableCell"><input type="text" name="S_PersonalExperience" id="S_PersonalExperience" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Category1:</th>
<td class="WADADataTableCell"><input type="text" name="S_Category1" id="S_Category1" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Category2:</th>
<td class="WADADataTableCell"><input type="text" name="S_Category2" id="S_Category2" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Category3:</th>
<td class="WADADataTableCell"><input type="text" name="S_Category3" id="S_Category3" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">OrgType1:</th>
<td class="WADADataTableCell"><input type="text" name="S_OrgType1" id="S_OrgType1" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">OrgType2:</th>
<td class="WADADataTableCell"><input type="text" name="S_OrgType2" id="S_OrgType2" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">OrgType3:</th>
<td class="WADADataTableCell"><input type="text" name="S_OrgType3" id="S_OrgType3" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">OrgTypesOther:</th>
<td class="WADADataTableCell"><input type="text" name="S_OrgTypesOther" id="S_OrgTypesOther" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">JobFunct1:</th>
<td class="WADADataTableCell"><input type="text" name="S_JobFunct1" id="S_JobFunct1" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">JobFunct2:</th>
<td class="WADADataTableCell"><input type="text" name="S_JobFunct2" id="S_JobFunct2" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">JobFunct3:</th>
<td class="WADADataTableCell"><input type="text" name="S_JobFunct3" id="S_JobFunct3" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">JobFunctOther:</th>
<td class="WADADataTableCell"><input type="text" name="S_JobFunctOther" id="S_JobFunctOther" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">JobTitles:</th>
<td class="WADADataTableCell"><input type="text" name="S_JobTitles" id="S_JobTitles" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">MentorTopic1:</th>
<td class="WADADataTableCell"><input type="text" name="S_MentorTopic1" id="S_MentorTopic1" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">MentorTopic2:</th>
<td class="WADADataTableCell"><input type="text" name="S_MentorTopic2" id="S_MentorTopic2" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">MentorTopic3:</th>
<td class="WADADataTableCell"><input type="text" name="S_MentorTopic3" id="S_MentorTopic3" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="Submit" name="Search" id="Search" value="Search" /></td>
</tr>
</table>
</div>
</form>
</div>
robcorrick409194
Full Files
Jason,
In case this makes it easier for you, attached are complete copies of the Search and Results pages.
can you provide a link where I could test the search and results to see the issue.
also, i will need you to compress the search and results files into a zip archive and send the zip file in your reply.
robcorrick409194
Search Multiple Fields
Here are the Search and Results pages both from Dreamweaver php and rtf files. You can see these pages in operation at users_Search2.php. This search brings the blank result.
If you go to users_Search.php. The search works well. This search does not have the key word search in it.
