Validation with Captcha
Thread begun 7/03/2012 2:01 am by Jaffa | Last modified 7/05/2012 12:52 pm by Jason Byrnes | 3134 views | 4 replies |
Jaffa
Just added a captcha security to a very basic to test a form with validation by following the manual but I can't seem to get it to work. I'm using the latest version of Design Extender.
The validation warning shows when the form loads rather than when a wrong code is entered and the form won't submit either.
File attached!
the first thing to test is to make sure the server is saveing session data correctly.
the following thread has a sessionTesxt.php script that can be used for this:
showpost.php?p=23826&postcount=2
Jaffa
Seems to be working fine using this sessionTest.php
So where to now?
Ian S
Have you tried adding <?php session_start(); ?> to the top of the page?
Cheers
Ian
like ian says, add the session start code at line 1.
also turn on error reporting by adding this code:
error_reporting
(E_ALL);
and find this code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"contactplastering_617");
and change it to:
    die($WAFV_Errors."<pre>".var_dump($_SESSION)."</pre><pre>".var_dump($_POST)."</pre>");
this will help us troubleshoot what is going wrong
