How to set a Session Variable
Thread begun 2/03/2010 7:32 pm by champcorp393068 | Last modified 2/04/2010 5:54 pm by champcorp393068 | 2854 views | 4 replies |
champcorp393068
I am 3 days in to using Security Assist, so be easy on me. I would like to set a "Session Variable" when the user logs in. Then allow access to restricted pages when the session variable is true (or equal to "1").
Currently when the user logs in, they are redirected to the "success" page. But when attempting to access protected pages (while logged in), access is denied. (The Server Behavior is set to restrict access based on the "pivisitors" rule).
My WA Rule is below:
function WA_Auth_GetComparisonsForRule($ruleName){
$comparisons = array();
switch ($ruleName){
case "Logged in to pivisitors":
$comparisons[0] = array(TRUE, "".((isset($_SESSION['sess_var']))?$_SESSION['sess_var']:"") ."", 1, "1");
break;
return $comparisons;
function WA_Auth_GetGroup($groupName){
$group = Array();
switch($groupName){
return $group;
PS. Also, please advise how/when I can access the Solution Recipes (swf's). The links appear to be broken.
On the login page, double click the SecurityAssist authenticate user server behavior.
On the Third step of the Authenticate user wizard, you can select columns from the user table that will be stored in session variables once the user logs in.
The Solution recipe links should be fixed in the next hour or so. sorry for the inconmvinience.
champcorp393068
Session Variable - Access Rules Manager
Thanks Jason for the reply.
I thought a session variable (and the solution recipes) would solve my problem, but no joy. Here's where I am. I have created an Access Rule and applied it to a page. The rule I need is simple. Only allow access to the page when logged in. However, the page can be accessed even when the user is not logged in.
I think my Access Rule is incorrect. I've attached a snapshot. Please help lead me in the right direction.
when the user is not logged in, the email session variable is = to unset
the criteria:
$_SESSION['email] == $_SESSION['email]
will evaluate to true because the session is unset, the equation becomes:
unset == unset
If the user is logged in, the session will NOT be equal to "" however. Leave the compare to field blank and set the criteria to "<>" or "!="
champcorp393068
Thank you Jason,
Worked perfectly!
