Insert Todays Date for Multiple Update (form within form)
Thread begun 1/06/2010 11:59 pm by jo4koalas392067 | Last modified 1/12/2010 3:41 pm by jo4koalas392067 | 2663 views | 3 replies |
jo4koalas392067
Hi
I have a query that I hope someone can help with. I have created a multiple update page on my web site, but I would like to update the "date amended" field to reflect the date it was amended. As not all records on the multiple update page are going to be amended I cannot put a blanket update date, but need to reflect each individual one. I could get the user to amend the date along with the other amendments, but firstly I can only get the date to reflect in SQL format in the text box e.g. YYYY-MM-DD and secondly it would be much easier if all they had to do was to hit a button and it was automatically inserted for them.
I guess even better would be that when they press update it updates the date amended field only for those rows that have been amended, but I think that would be too complicated as this particular page combines 2 tables on one row.
I have attached a copy of my attempt with a submit button on the same line, which goes to the same page once submitted, but I cannot get it to update the amended date.
Any help would be gratefully received.
Jo
the first update record behavior on your page is set to redirect to the StateList.php page, the redirect is occurring before the second update behavior has a chance to update the amended column, remove the redirect from the first update record behavior on the page.
jo4koalas392067
Hi Jason
I am sorry I probably didn't explain myself very well. So maybe if you have look at a live page it would help: stateoccvisajoinmulti_Update.php?StateID=2
I would like the user to be able to press the button marked "Insert Todays Date" and update the "Date Last Amended" so only the date gets amended in the rows that are to be amended. Then press the "Update" button to update the whole page.
I guess it would be better to try and explain what I am trying to achieve and maybe you can let me know if this is the best way to do this or whether there is a better way.
There are 2 tables joined here on this multiple update page and when the page displays it displays all the information from these 2 joined tables relating to that State, so that the user can update the occupation details where they need amending. Not all occupations are going to be amended, so we can't do a blanket update of the "Date Last Amended" to the current date and it would be too painful to update each occupation individually, so I am looking for a way that the user can amend the date to the current date only on the rows that have actually been amended.
I have tried inserting in a text box field for the "Date Last Amended", but the date displayed (and entered) is/needs to be in SQL format (YYYY-mm-dd), which is not natural for someone to type and leads to typing/entry errors.
I would be grateful for any solution.
Jo
jo4koalas392067
I don't seem to have received a response to this one? Does this mean it cannot be done, if so I would be grateful if someone could let me know.
If it cannot be done, is there a way that dates can be inserted in a user friendly way e.g. dd/mm/yyyy and not SQL format?
