ECART Checkout Wizard - No Email Prefs
Thread began 11/19/2009 3:39 pm by Jaffa | Last modified 11/24/2009 6:15 pm by Eric Mittman | 2274 views | 7 replies |
Jaffa
Hi again,
Just running throught he checkout wizard and watching and reading the tuts, however it states that if you have Universal Email 2+ and beyond that you will be presented with an extra step to setup the email preferences, I have UE but I never get prompted to setup these options?? Any idea why?
Jaffa
Anyone please or can we open a ticket up for this, I would like to know why the wizard does not give me Universal Email options at the end of the order parts.
What is the version of UE that you have installed and what version of DW are you working with? Also what is the version of eCart you have installed? Have you used Universal Email in this site anywhere? If not you should create a new page and try applying Universal Email to the page. Please post back and let us know this info along with the OS you are working with and any other details that you can come up with.
Jaffa
Universal Email 3.0.7
ECart 4.5.2
Dreamweaver CS4
Yes I have a UE server behaviour in my site already but the check wizard skips the setup of the email account and goes straight to the style I want.
Having both of these extensions installed and having used UE on the site should allow you to have the receipt email setup pages in the wizard. The only time that these options will not appear are when you are not using a local checkout. If you are using any of the remote or non local checkouts you will not have this option available to you from the wizard.
I have opened a ticket for you on this issue in case you are using a local checkout and still have this problem. If so please update your ticket by logging into the site and visiting your support history.
john275907
Same issue here !!
I have the same issue.
My config is:
XP Pro
DW CS4
eCart 4.5.2
UE 3.0.6
eCart to use PP Website Payments Standard.
No shipping required.
Yesterday and today I have gone thru the Checkout Wizard process at least THREE times and read and re-read the GSG pdf as well as the Help files and I did not find any mention of the limitation that Eric mentions:
" If you are using any of the remote or non local checkouts you will not have this option available to you from the wizard."
I find this astounding !! This should be immediately addressed in the documentation.
Not only that, the following issues were experienced:
In the first screen of the CO Wizard I elected not to offer shipping services. However, I want the user to be able to have the ability to include a delivery address. The Checkout Form that gets created does not provide this option. In a previous site I used Paypal Website Payments Pro and this option is supported in the resulting Checkout Form - in that site, I did not offer shipping services either. Why is the Shipping section of the Checkout Form not supported/included when using PP Website Payments Standard ??
A minor irritation was experienced with the Display Manager when I ran (TWICE) the QuickCart option. The Cart Summary includes a form in which the View Cart, Clear Cart and Checkout buttons are placed. The View Cart button code includes:
"onclick="MM_goToURL('plugins/parent','cart.php');return document.MM_returnValue"
The JS function MM_goToURL NEVER gets included in the page. This occurred in the previously mentioned site as well so this must be a BUG ! And, the second attempt to run the Quick Cart wizard the "return document.MM_returnValue" section of the link was not included.
The last point I want to mention is the fact that when running the Checkout Manager I was working on the fields for the Order Details and wanted to go back to the previous step. I clicked on the Back button and the wizard would no longer display the Order Summary or Order Details info and I had to cancel. This occurred on two occassions and is probably repeatable. But I wont waste any more time on that issue.
Not impressed !
Jaffa
It should allow me to but it doesn not!
To Jaffa, if you are using a local checkout and having this issue you should login to the site and update your ticket to include additional details.
To John, you will not have the email option available to you because of the way that the remote checkouts work versus the local checkouts. During a local checkout the email receipt is sent after the user confirms the order and the status of the transaction comes back as successful. In a remote checkout situation it is not possible to confirm the status of the order when it is submitted, therefore sending out an email receipt would not be appropriate without first knowing this status.
For the shipping you must specify that you will be offering shipping in order to have the shipping part of the form included. If you do not wish to use the real time shipping quotes then you will just select none for the provider when configuring the shipping details in the wizard.
When it comes to the view cart code I will do some more investigating into this to see why this is not being defined on any of the pages.
For the orders info please explain the exact steps that you took up to this point before you clicked on back and I can check on some things to see what may be going on.
