Can I use ecart for this sort of selection page?
Thread begun 11/02/2009 2:24 pm by jspencer190495 | Last modified 11/04/2009 4:14 pm by Eric Mittman | 2144 views | 3 replies |
jspencer190495
I'm trying to use eCart for the first time, so I'm really feeling my way here. However, I have used other WebAssist extensions in the past so I'm reasonably confident I can work my way into it if it's possible. Here's what I'm trying to do:
I have a product page here:
stockbdprogram.htm
that allows the visitor to select different quantities of seven different product sizes. Yes, I know it's an .htm file and will eventually have to be an .asp or .php file; this is just a mockup to display the interface before I build the backend.
My question is this: Is it reasonable to expect that I can make eCart take the data from this page and enter it into the cart page correctly?
I'm using a static cart because this is the extent of the product line at this point. However, if you think I need to use the dynamic cart I can do that - I'm just assuming that the simpler version will work.
Finally, if this is possible, can you give me a little guidance as to how to do it or at least where to start in the eCart system?
Thanks in advance.
Jon
I can think of a way that you could do this but it is fairly custom and not a supported feature of the cart. The idea is that you would have static add to cart buttons for each available item sizes on this page, each item with a different size would be considered unique.
Once you have got all of the add to cart server behaviors on the page the next thing to do is to combine all of the forms so that there is only a single add to cart form. This part could be tricky if you are not comfortable with editing the html directly. You need a single form with a single submit button.
After you modified the forms so there is only one you would need to modify the add to cart server behavior code. It would need to have the triggers for each updated to be based on the posted quantity for that size. This way the sizes for the items will only be added based if they have entered a quantity.
After all of this you would need to check the redirects that are on the page and make sure that the eCart redirect code only occurs after all of the add to cart code.
The trickiest part of this is combining the forms and editing the code for the add to cart server behaviors. If you are interested in going this route you should first get a single add to cart on the page working, then once it is working you can add another and combine them. If you can combine two on the page combining more should not be a problem. This is a custom feature and will not be supported itself but if you need any advice or pointers on how to get things going please post back and we will be glad to help you with whatever we can.
jspencer190495
Thanks Eric. Editing the HTML won't be a problem. Editing the cart server code might be more of a challenge.
Well, OK, I will take a crack at this and see where I get. Starting by getting it working with a single form seems to make sense so I'll work on that. I expect I'll be back after I start digging into the cart server code.
Jon
Sounds like a good plan to me, post back and with any questions that you have about any part of this, we will be glad to help you with what we can.
