Image uploading with HTML Editor
Thread begun 10/28/2009 1:02 am by simmo515303621 | Last modified 11/25/2009 5:51 pm by Eric Mittman | 15546 views | 17 replies |
simmo515303621
I was hoping you could please help me with the new HTML editor
I have been frustrated with this for 2 days now - it has not been a simply upgrade to my existing iRite pages
I have build a CMS backend system located at iS_admin
As I have a site defined specifically for my Admin section only, but of course it is a sub_folder on the server
I specify my upload folder as /userfiles/
but HTMLEditor upload my images to userfiles/
not userfiles/
If I go insert an image then goto the upload tab - browse for an image then send it to the server.. that will work
although sometimes I will need to click the refresh height and width to see the image
the URL that shows up is /iS_admin/userfiles/nameofimage.jpg
but If I click to insert an image then browse server
I can see the images and I can also upload to the server form there
but when I double click to insert the image the URL returned is /userfiles/nameofimage.jpg
of course it is missing the /iS_admin/ and if I append that to the URL it works.
If in the initial set up of HTML editor I choose /iS_admin/userfiles/ as the upload path I get an error that mkdir can find or create that folder or something like that.
I have also found that if I goto the HTML Editor Site Settings and redefine anything, I need to re-upload the entire HTMLEditor folder as I dont know which files have been modified - it seems there is the config.php but it seems to be defined in other files as well - as there is no documentation I do not know what to re-upload...
anonymous
If you specify your folder as "/userfiles/" then it will go to userfiles.
The forward slash BEFORE your folder name makes the path relative to ROOT - not the page. If you want to make the path relative to the page... meaning your page is in the same folder as your "userfiles" folder - which you specified as admin, you need to either make the path relative to the page like this "userfiles/" with no forward slash or create a root relative path like this "/admin/userfiles/". Also, be sure to set your permissions.
simmo515303621
Still not working
ok So I've tried each combination
iS_admin/userfiles/ give me the following error
Warning: mkdir() [function.mkdir]: No such file or directory in /home/internet/public_html/iS_admin/HTMLEditor/editor/plugins/kfm/initialise.php on line 128
error: "../../../../iS_admin/userfiles/" could not be created
same for /iS_admin/userfiles.
userfiles/ and
/userfiles/
Gave me the same result as my previoust post
I think you are close with this last attempt, you should try it with this your path and include slashes at both ends like this:
Based on what you have posted here I think this will get you the result you are looking for.
simmo515303621
Yes sorry I have tried that as well
iS_admin/userfiles/
Both give this warning
/userfiles/
userfiles/
Give me the same issue as my original post
anonymous
Hi there,
Not sure if you saw my earlier suggestion about permissions... can you confirm that the permissions are set correctly on the folder. The error you are getting is very similar to what happens when the permissions are not set on the folder you are trying to upload to.
Let me know and then I will go back to the drawing board.
Brian
simmo515303621
Yes the permission are definetely set correctly -
Office Guy-172461
Originally Said By: simmo515303621
I can't see anything wrong with the paths in the error message but since it's being triggered by the mkdir() comand, have you tried deleting that folder and letting it create it from scratch?
simmo515303621
Yes I have also tried that as well - does not make any difference
I have opened a ticket for you on this issue. To check the status of the ticket or make any updates to it login to the site and visit your support history.
