Will we see more Ajax-style functionality in future releases?
Thread begun 10/09/2009 10:06 pm by Lon Winters | Last modified 11/12/2009 11:52 am by carlene | 3540 views | 4 replies |
Lon WintersBeta Tester
I was just reading a thread in the UE forum about using email to validate a user registration. The expert provided a well-detailed solution using Data and Security Assist and UE.
The solution included the standard set of registration and login pages, as well as the check new username function. If the user name exists, then direct to another page. This is the way we've been doing it for years, even if we only use the standard DW behaviors. But most registrations I've filled out lately check the username without any redirect. Just click the button, the little loading wheel spins and then you get a message.
Is this type of functionality present in any of the data type extensions, or will it be? It would be nice to build sites that match the modern world with the help of the library.
Because we use triggers and server validation, you can actually do this now with our extensions now. It is just a little more complicated since you need to add the functionality to a separate page and use AJAX to submit.
We will definitely be creating more tutorials on how to take advantage of AJAX and other new techniques as we move forward.
Yes, I'm all for more tutorials. But building this functionality into the extension itself, through the visual panels - is this actually limited by the nature of extensions in general?
The issue with modifying any server behavior code - whether it's native DW, or 3rd party extensions is that it "breaks" the entry on the panel, and then you can't open it for further editing. I don't know how many times I've had to created a backup copy of my modified, working file, and start over so I could use the interface, then past the modified code back in.
And the stuff I'm thinking of is all data related, and it's all done without page refresh. Such as:
1. Check for existing User name.
2. View the Detail of the selected record by expanding the content to display a region.
3. Update a record!
4. And there's more, they're all over the net, Facebook is a good example. And they all need that little circle loader, and grey out the button once is pressed!
I'm getting ready to throw the switch on my subscription, and maybe some of this stuff is in there already, but if I knew WA was heading in this direction I would be more enthused. You gotta admit that the whole "page set' approach is getting old, almost deprected, eh?
Does anyone else share this opinion, or am I the only one?
We will definitely be using more AJAX in the future. We are incorporating more and more into our solutions and extensions.
carleneBeta Tester
Could you please provide the link to that UE solution?
Dear Lori - That solution discussion is exactly what I've been looking for! Do you think that you could provide a link to this for me (and others, I'm sure.)
And Ray - could you please mention to your documentation folks that there are MANY really fabulous solutions to most of the problems your users have with the software integration hidden within these forums. Unfortunately the forum searches take a while and they're difficult to find.
Why couldn't these solutions just be put into F.A.Q. solutions that could be found within the Extension's support files? I'm thinking that weekly this should be done. I've found most of the solutions through the forums, with some support from the documentation.
Thanks!
Carlene
