error conection
Thread begun 10/01/2019 7:19 am by QuiruNet | Last modified 10/01/2019 12:03 pm by Ray Borduin | 1185 views | 3 replies |
QuiruNet
error conection
http Error code 406 acceptable. I can not connect with the data base, i am using wa database..but i get this error. Can you help me. thanks
Try reinstalling the latest version of the extension. This looks like it could be an issue that has been addressed. If you still have problems, I'll probably need FTP access so I can set up a connection and test from Dreamweaver and see the issue. Maybe you could export your site definition and send it to me. That way I can make sure there are no site settings that are wrong and debug it from my end.
QuiruNet
it is the latest version
I see the error.... my only guess is thay you have a mod_security rule preventing Dreamweaver from doing a POST to a web page on your server. This prevents Dreamweaver from connecting to the database.
I think your only solution is going to be to talk to your hosting provider to get around the security rule, or set up a testing server on your local computer with a copy of the database and use that for development.
