utf-8
Thread begun 12/19/2016 12:25 pm by JBWebWorks | Last modified 12/22/2016 5:35 pm by Ray Borduin | 4259 views | 6 replies |
JBWebWorks
utf-8
I have changed the smtp char set to utf-8 and in my server php.ini changed my default_charset to utf-8 but when i send email with ' or " or / in the mail body, I see \' or \" or /\ or even ’
I have also changed the apache default char
The email body comes from a text area that uses JavaScript for a rich text editor; don't know if that affects the setting for utf-8?
Including code from pages
$MailAttachments
$MailBCC         = "";
$MailCC          = "";
$MailTo          = "";
$MailBodyFormat  = "";
$MailBody        = "";
$MailImportance  = "";
$MailFrom        = "".((isset($_POST["from1"]))?$_POST["from1"]:"")  ."";
$MailSubject     = "".((isset($_POST["subject1"]))?$_POST["subject1"]:"")  ."";
$_SERVER["QUERY_STRING"] = "";
//Global Variables
$WA_MailObject = WAUE_Definition("","","","","","UTF-8");
if (
$RecipientEmail)     {
$WA_MailObject = WAUE_AddRecipient($WA_MailObject,$RecipientEmail);
else      {
//To Entries
//Additional Headers
//Attachment Entries
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".(AttachFromUpload("attach"))  ."");
//BCC Entries
//CC Entries
//Body Format
$WA_MailObject = WAUE_BodyFormat($WA_MailObject,0);
//Set Importance
$WA_MailObject = WAUE_SetImportance($WA_MailObject,"3");
//Start Mail Body
$MailBody = $MailBody . "<html><head></head><body><br />\r\n";
$MailBody = $MailBody .  ((isset($_POST["message1"]))?$_POST["message1"]:"");
$MailBody = $MailBody . "</body></html>";
//End Mail Body
$WA_MailObject = WAUE_SendMail($WA_MailObject,$MailAttachments,$MailBCC,$MailCC,$MailTo,$MailImportance,$MailFrom,$MailSubject,$MailBody,"waue_emailgroup_1");
if (isset(
$GLOBALS["waue_emailgroup_1_Status"])) {
$MailLogBindings = new WAUE_Log_Bindings();
//Start Log Bindings
  //End Log Bindings
$MailLogBindings->SuccessOrFailure->MailRef = "waue_emailgroup_1";
$MailLogBindings->Success->MailRef = "waue_emailgroup_1";
$MailLogBindings->Failure->MailRef = "waue_emailgroup_1";
$MailLogBindings->processLog(($GLOBALS["waue_emailgroup_1_Status"] == "Failure"));
$WA_MailObject = null;
code from page that generates the email
<?php require_once('Connections/connmpmga1.php'); ?>
require_once( "webassist/security_assist/helper_php.php" ); ?>
if (!WA_Auth_RulePasses("Logged in to admin")){
WA_Auth_RestrictAccess("admin_login.php");
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
  if (
PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
      break;
  return
$theValue;
mysql_select_db($database_connmpmga1, $connmpmga1);
$query_rs_members = "SELECT members.EmailAddress FROM members";
$rs_members = mysql_query($query_rs_members, $connmpmga1) or die(mysql_error());
$row_rs_members = mysql_fetch_assoc($rs_members);
$totalRows_rs_members = mysql_num_rows($rs_members);
require_once("webassist/email/mail_php.php"); ?>
require_once("webassist/email/mailformatting_php.php"); ?>
if ((isset($_POST["submit1"]) || isset($_POST["submit1_x"])))     {
//WA Universal Email object="mail"
@session_write_close();
set_time_limit(0);
$EmailRef = "waue_emailgroup_1";
$BurstSize = 50;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "?success=true";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex][] = $row_rs_members;
$RecipArray[$CurIndex][] = $rs_members;
$RecipArray[$CurIndex][] = "EmailAddress";
$TotalEmails += mysql_num_rows($rs_members);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
  if (
$TimeRemaining < ($TotalEmails*$RealWait) )  {
$TimeRemaining = $TotalEmails*$RealWait;
writeUEProgress($EmailRef,0,$TotalEmails,$TimeRemaining);
  while (
$RecipIndex < sizeof($RecipArray))  {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
    while ((
$EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
      if (
$EnteredValue)  {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
      }  else  {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
      if (
$AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
      if (
$TimeRemaining < ($EmailsRemaining*$RealWait) )  {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
writeUEProgress($EmailRef,$LoopCount,$TotalEmails,round($TimeRemaining));
wa_sleep($WaitTime);
      include(
"webassist/email/waue_emailgroup_1.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
      if (
$LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex]))  {
$TimePassed = (time() - $StartBurst);
        if (
$TimePassed < ($BurstTime*60))  {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
        else  {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
      if (!
$EnteredValue)  {
$RecipArray[$RecipIndex][0] =  mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
session_start();
$_SESSION[$EmailRef."_Status"] = $GLOBALS[$EmailRef."_Status"];
$_SESSION[$EmailRef."_Index"] = $GLOBALS[$EmailRef."_Index"];
$_SESSION[$EmailRef."_From"] = $GLOBALS[$EmailRef."_From"];
$_SESSION[$EmailRef."_To"] = $GLOBALS[$EmailRef."_To"];
$_SESSION[$EmailRef."_Subject"] = $GLOBALS[$EmailRef."_Subject"];
$_SESSION[$EmailRef."_Body"] = $GLOBALS[$EmailRef."_Body"];
$_SESSION[$EmailRef."_Header"] = $GLOBALS[$EmailRef."_Header"];
$_SESSION[$EmailRef."_Log"] = $GLOBALS[$EmailRef."_Log"];
  if (
function_exists("rel2abs")) $GoToPage = $GoToPage?rel2abs($GoToPage,dirname(__FILE__)):"";
  if (
$GoToPage!="")     {
header("Location: ".$GoToPage);
and this is the javascript for the rich text box
<div id="sample">
<script type="text/javascript" src="http://js.nicedit.com/nicEdit-latest.js"></script> <script type="text/javascript">
//<![CDATA[
bkLib.onDomLoaded(function() { nicEditors.allTextAreas() });
</script>
</div>
Are you setting the charset on the page as well in the head like:
<meta charset="UTF-8">
JBWebWorks
Ray,
Yes I have this on the page that generates the emails
If you give me FTP access I can try to track it down. I think you can specify the language in the editor as well, but I forget where. I'd try adding a textarea and see if it has the same problem to narrow down if it has something to do with the editor or not.
JBWebWorks
Ray,
I did try with a plain textarea and had the same problem.
The page sends dynamically to about 100 email addresses.
See PM for ftp info
You have "magic_quotes_gpc" enabled on your server. This is a horrible and deprecated feature that can cause issues like these. I'd suggest turning it off if possible, but I've also added a script to the top of your page that will undo the mess magic quotes causes.
JBWebWorks
Ray,
Thanks for your support. I tested and it fixed my email problems.
I will disable magic_quotes_gpc.
Merry Christmas and Happy New Year to you and Webassist!
