Add email account password to form
Thread begun 12/02/2015 8:54 am by Paul | Last modified 12/04/2015 8:14 pm by Ray Borduin | 2526 views | 6 replies |
Paul
The form I have created works, as long as the "to" email is not within the same domain of the "send". After dealing with Rackspace, I feel that the issue might be that I need to add the "Include from" email address AND password to the form.
Where would I enter that information?
I have included the file, if needed.
I'm not sure what you mean by "Include from" email address AND password.
I'm also not sure why it would matter if the to and from were from the same domain? So if you change the from to a different domain it will send? Perhaps you just need to register the FROM address so that it is a working email address.
Paul
In the UE2 server behavior, if you go into the "Mail Object Settings", there is a check mark for the Include from address using additional parameters. I assumed this would be if the emails are not going through and required the senders email address and password?
I have used the same domain for the "from" and the "to", but they do not get received. If I change the "to" to another email address on an external domain, they arrive.
I read another posting here from Jason that made reference to some email services not liking if both sender and recipient are on the same domain. That made sense to me because the client is not receiving the form on his own domain, but I am receiving it if I use my email address which is separate from theirs.
I think it doesn't work if you use the same from an to domain if one of the two aren't valid, but should work in general. Make sure both the from and to domains are set to a valid email address registered with the domain email provider and they should go through.
The settings include the "Reply to address", which can be set separately from the from address. The additional parameters aren't necessary for you since it works in some cases, that isn't the problem in your case.
If you need to send authenticated email with username and password, then you have to change to PEAR mail.
Paul
The email address they originally wanted it to go to was an alias. Contactus@... Could that be the problem?
Right now, even using 2 different, but valid email address in the same domain, it is not being received.
So I'm still at a loss. If I send it outside their domain, it is received.
It is probably a spam filter in the email server.
The email server sees a message coming to it that claims it comes from it, but the SMTP server knows it didn't send the email, so it is rejecting it as spam.
You may be able to ask your server administrator to adjust the SMTP sever settings to allow the emails to be delivered.
Paul
Ray,
Thank you for all your follow-up help. The problem is fixed and it turned out to be a GoDaddy situation. The website is hosted with Godaddy and the email is with Rackspace. This would need to change in any website on godaddy that is using an outside source for email.
In Godaddy's CPanel, under the Email section, you select the MX Entry and change the Local Mail Exchanger setting to Remote Mail Exchanger. This allows GoDaddy to send email on a form through a Remote system.
Just in case anyone else has this issue...
