dynamic list not working correctly when viewing results, details pages
Thread begun 9/13/2015 9:58 am by software.current355386 | Last modified 9/15/2015 10:07 am by Ray Borduin | 3092 views | 9 replies |
using the database page creation option, fill in all the details,when i need to create a dynamic list
change the text field to list , using the lighting bolt fill in the details of the database to use for the list, then generate the pages
insert - shows list, make selection- nothing retained
all other pages not showing anything
ising the sharp preset the update button shows ok in dw but when previwing in safari its dark gray
have i done something wrong
Mac runnin yosemite
Please post a copy of the pages and I can take a look.
loin to website
url listed inpm
It looks like you are using Multi-select lists. How are you expecting that data to be stored? A single record comma separated? In a separate related table?
The Data Bridge interface doesn't do Multi-Select lists like this by default, but I can help you edit the pages to do what you need them to.
all lists are populated from own table
nb only ares has two list
if you could poinme in right direction to get thes workig will be great
ay idea why the button on update creen for all tables is wrong
It looks like the css path was converted to a file:// path at some point. It has:
<link href="file:///Macintosh HD/Applications/MAMP/htdocs/websites/delta-sds-903/webassist/forms/dataassist_button.css" rel="stylesheet" type="text/css" />
but it should be:
<link href="../webassist/forms/dataassist_button.css" rel="stylesheet" type="text/css" />
Did you mean for those to be multi-select lists? Or should users only be making one selection?
only one entry selected i.e. screened lists4 enties at moment , like to select home page and tht shows trouhout unleess rselct unassigned via update
Remove the word "multiple" from the select list tags and remove the brackets at the end of the select list names. Also update the classes to use Menu instead of List classes.
So for instance the screen ID field should be:
<select id="AreaLocalScreenID" class="formMenufield_Medium" title="Please enter a value." tabindex="2"  name="AreaLocalScreenID">
most working now apart from this error with ckeditor
DrivingTip:
Fatal error: Class 'CKEditor' not found in /Applications/MAMP/htdocs/websites/delta-sds-903/admin/drivingtips_update.php on line 127
It looks like it didn't add the library file it uses... just add this to the top of the page:
<?php require_once("../webassist/ckeditor/ckeditor.php"); ?>
