Dreamweaver and php pages
Thread begun 2/11/2015 1:33 pm by dmrick44 | Last modified 2/12/2015 2:40 pm by dmrick44 | 2821 views | 4 replies |
dmrick44
When I created my Registration and LogIn pages, Dreamweaver insisted that I have a php page open before I could create a database connection.
So I simply created a "Untitled-1.php" page and saved it. Now I'm trying to get things organized so that I can set up my Registration and LogIn Redirects... and so I don't want to have to edit names later. Why does Dreamweaver insist on there being an open php page when it doesn't seem to do a thing to it? After creating all of the Registration and LogIn pages, can that first php page be deleted?
My site's home page will be index.html where one will either go Register, or go LogIn. With a successful LogIn they'll be redirected to a different html page that would normally look like a home page, with info, links, etc.
I guess what I'm asking is, how would you set things up?... What's the standard practice?
Thanks.
Dreamweaver needs tho have a PHP page open so that it knows 2 things?
1) What Dynamic language you are using
2) What site it should be using.
normally, with a dynamic site, all pages would be php, so instead of having index.html, you would have index.php
then opening that page, you would start the Security Assist wizard.
Security Assist cannot add access restriction to a .html page, so it really does not make sense to redirect after login to an html page, that page would be accessible whether the user is logged din or not.
The standard practice would be:
Open index.php and start the security assist wizard.
after the security assist wizard is completed, it will open the access pages manager, select the php pages that should only allow access to logged in users and apply the logged into <your users table> access rule.
if you want to change the redirection for login success, open the login page, open the server behaviors panel, and double click the Security Assist Authenticate user server behavior to change the login success page.
dmrick44
In my case I don't want anyone to access any pages except Registration and LogIn (or failure to login) and so all of my pages should end in php and I should use the Access Pages Manager and set all other pages to "Logged in to users."
So, my index.php page will have the usual graphics and only a "Register..." and a "LogIn" link on it. Once a person successfully logs in they can then be redirected to something like "main.php" with its access set to "Logged in to users." Right?
yes, if all pages in your site should be protected, then they will all need to be php pages with the Logged into users access url applied.
you can set the logged into users access rule to redirect to the login page.
dmrick44
Just got my Register and LogIn pages working. I wanted to have a person log in with a username rather than an email, but the way I was doing it must have been the reason things weren't working right. When creating the various security pages, I went inside the "Manage Pages" tab and and changed User name to UserID... display as Text... and made it a required input... Which showed "Username" instead of "Email" on the Register and LogIn pages, but didn't really work well.
Want to let others know that when I first considered purchasing you product, I hesitated at the price, but now after purchasing it and seeing how powerful it is, anyone considering building a website should definitely have this program!
