Paste from word issues
Thread begun 8/09/2009 8:32 am by raw8888 | Last modified 8/12/2009 3:57 pm by Eric Mittman | 2772 views | 3 replies |
raw8888
Our Sites allow clients to paste their resumes into an Irite textarea. If you right click to paste , the pop-up box opens and the document that is pasted into that box transmits fine. The problem occurs when the client controls V directly into the textarea... the paste box does not appear , the copy goes into the area but the resulting transmission is :
Resume: <p><meta content="text/html; charset=utf-8" http-equiv="Content-Type" /><meta content="Word.Document" name="ProgId" /><meta content="Microsoft Word 11" name="Generator" /><meta content="Microsoft Word 11" name="Originator" /><link href="file:///C:DOCUME~1OwnerLOCALS~1Tempmsohtml1
the resumes are not put into a database but are sent via email.
also when the text is transmitted correctly (using the pop-up box), this line appears above the resume:
Normal 0 false false false MicrosoftInternetExplorer4
thanks
When you are in the iRite wizard on the formatting tab do you have the checkbox for 'keep structure from Word' checked? This option should allow you to paste from word and retain the structure. Please give it a try with this option enabled to see if you get a better result.
raw8888
yes it is checked...it works as designed as long as you right click into the text area... I need to prevent the user from control V directly into the textarea because that is when it breaks down.
I have done a bit of searching around on this and have experimented with some code examples. In my testing I was not able to successfully capture the ctrl + v to prevent the pasting.
It seems to me that this may be possible but it would require some custom js coding to add this in. In the examples I saw you will have a special function that is called in the onkeyup or onkeydown events. This function basically checks for the control key and the v key being pressed at the same time. In most of these functions they use the following for the ctrl key:
event.ctrlKey
event.modifiers & Event.CONTROL_MASK
They make reference to the v key as:
event.keyCode == 86
event.which == 86
The function I was working with set variables to these values then in an if statement just look for both of the variables together. If true it would just clear the text field.
While this may be possible to do with the code getting it implemented correctly could present a bit of a challenge if it is not something you are familiar with.
