Changing 'Learn More' button font
Thread began 9/07/2012 3:41 am by stottiecake442163 | Last modified 9/07/2012 8:58 am by Jason Byrnes | 4752 views | 1 replies |
stottiecake442163
Hi
Is it possible to change the font contained within the 'Learn More' buttons. I'm able to change all of the other wording when customizing except these - they stay as Arial font.
If not, is there any way around this?
In the Cafe Commerce admin section, go to the Design tab, Advanced section.
you can add custom CSS Here. the learn more buttons are a tags using the button class, you can use this css to set the font family:
a.button { font-family:Verdana, Geneva, sans-serif; }
stottiecake442163
Thanks, I've managed to change the 'Learn More' button font with this code, but realised this does not change some of the other button fonts, such as 'Add to Cart' and related Cart buttons, and the Coupon Code 'Apply' button (and possibly others).
Is it possible to also change the font on these?
Thanks for your help.
if you use Firebug in Fire Fox, it will allow you to inspect element s on your page to find class names or IDs that you can use to create advanced style.
for example, the add to cart buttons are a submit input type, that have the class of "button"
so the following css can be added:
input.button {font-family:Verdana, Geneva, sans-serif; }
for details on using Fire Bug, see the following page:
roadmap_10.php
