Connecting PowerCMS to existing MySQL database
Thread begun 8/01/2012 8:24 am by designer-images | Last modified 8/02/2012 5:52 pm by designer-images | 1955 views | 2 replies |
designer-images
Hi there, I appreciate any assistance on this issue...
I'm adding a PowerCMS section to an existing static webpage, so I've gone through the procedure of converting the page to .php and establishing a localhost database using MAMP locally on my Mac.
Everything works fine locally, but it's installing online I feel I'm starting to come unstuck. The site I'm updating already has a database I have installed previously for an online store. The webhost is only allowing one database for this site, so I have to try and utilise the existing database for the PowerCMS setup on this particular page.
Don't know if this is where the issue lies (forgive me if I'm going off track)... the default MySQL local settings through MAMP is Host: localhost / User: root / Password: root. However I'm unable to create a database with those specs online as the phpMyAdmin only allows minimum 5 letter passwords.
Also the prefix automatically created for the online database name... [prefix]_[database name] is different to any database name prefix created locally.
Any help or at least any online guides in making the transition from a local setup to an online installation that you can forward onto me would be greatly appreciated.
Cheers,
Andrew
to transition from the local site to the live site, you will need to first export the tables that where created in the local database using PHPMyAdmin or another MySQL GUI Tool, then import the tables to the remote Database.
after that has been completed, you would need to update Connections/PowerStoreConnection.php file to connect to the remote MySQL Database.
When using Power CMS Builder, it is usually easier to set the DW Site up to use the remote Server as the testing server so that there is not a need to do the transition after CMS has been created.
designer-images
Thanks Jason for getting back to me with this one. Yes I agree it would be easier to do the initial setup using the remote server with the installed database, but the webhost doesn't allow remote connections. Their antiquated setup has been causing me headaches for some time :-(
Anyway I managed to manually make the connection change from local to remote editing the PowerStoreConnection.php file and now I'm in business. So thank you for your help!
