Use Frameowrk to create page ?
Thread begun 6/07/2012 4:35 pm by amucino12002 | Last modified 6/08/2012 10:18 am by amucino12002 | 1968 views | 4 replies |
amucino12002
I am trying to understand how I can use Framework to create a page that has the following:
A top part that will always display an image (Path comes from database) and the horizontal menu bar, which also stays static
The middle will display the body, which will change depending on what user selects from the menu
The bottom bar which displays a logo and some other image.
should be 20% top
70% middle
10 % bottom
I used to have frames to display 3 pages but seems like frames are now being replaced by includes and apparently by plugins ? ...
What would be the steps to use Framework if at all possible ?
Framework Builder Plugins allows you to create the aspects of your site in separate pages, then "plug" those individual pages into a main master page to create you layout
create one page that contains the menu and the header image. the menu links should point to the main design page using a querystirng variable that will determine the content to pull in:
index.php?page=aboutus
create another page that contains the footer content
create each of the content pages.
then create a main page page that has your layout on it.
Add a Framework builder plugin to the header section to add the header page to the layout.
add another plugin to the footer section to include the footer content.
make sure the bindings panel has a binding for the URL variable you are using. Click the plus button and select URL Variable, to create one. use the same name as your links, MyExample above uses the name "page"
Add Dynamic Plugin to the content area of your page. for the trigger click the lightning bolt icon and select the URL Variable that is used in your menu.
add each main content page to the list and the URL Value that is used to load it.
amucino12002
Ill try this today. One problem I face is the top menu when user scrolls down is lost, i need the top (logo and menu) to stay in place. I used to achieve this with frames but seems like frames are no longer supported. Is there a way to do this now ?
you would need to use CSS to create a fixed header.
I found the following tutorial through google:
fixed-header-footer-layout-a-beginners-guide-/
amucino12002
Thanks, Ill look into it
