Digital file Pro - image is lost in update file
Thread begun 5/10/2012 9:12 am by ori382079 | Last modified 7/11/2012 12:48 pm by Jason Byrnes | 7293 views | 9 replies |
ori382079
Please assist me, I 'm using Digital file Pro to upload images but the image is not shown whenever an update takes place in the record. The image file path is completely lost during update, displaying a tiny image placeholder in the result page or elsewhere.
I would expect the image path to remain if not updated.
Please see that attached file.
Thanks for you prompt action.
see the "Applying File Upload to DataAssist Insert and Update pages (PDF)" tutorial on the data assist support page.
basically, you need to add a hidden form element to your page, Set the initial value of the hidden element to use the image column from your recordset, then in the Upload file behavior, bind the default file setting to the hidden element.
ori382079
Re:Digital file Pro - image is lost in update file
Hi Jason, thanks for the quick response.
I had followed the instruction carefully, but when I need to update any record (other than these 2 fields), the thumbnail and product image fields return no data, and when I submit the updated record, the thumbnail and product image fields have no images in them.
The fields in this updated record show the missing image icon.
Please I include the details in the attached doc in order to reproduce it.
in the upload file behaviors, you have bound the Default File to the Image and Thumbnail File Fields.
You _should_ be using the bindings for the ProductThumb and ProductImage hidden form elements instead.
t.weijers438628
is it ok now?
Hi, i like to know if your problem is solved now.
i'm struggling about the same issue, tried several solutions, also the pdf in the support, for hours....
but, i can't get it working....
thnx.
Tom
please post a copy of your page so I can see the code.
t.weijers438628
copy of file
<?php require_once('../Connections/connamsterdam.php'); ?>
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
if (!isset($_SESSION)) {
session_start();
$MM_authorizedUsers = "administrator,user";
$MM_donotCheckaccess = "false";
// *** Restrict Access To Page: Grant or deny access to this page
function isAuthorized($strUsers, $strGroups, $UserName, $UserGroup) {
// For security, start by assuming the visitor is NOT authorized.
$isValid = False;
// When a visitor has logged into this site, the Session variable MM_Username set equal to their username.
// Therefore, we know that a user is NOT logged in if that Session variable is blank.
if (!empty($UserName)) {
// Besides being logged in, you may restrict access to only certain users based on an ID established when they login.
// Parse the strings into arrays.
$arrUsers = Explode(",", $strUsers);
$arrGroups = Explode(",", $strGroups);
if (in_array($UserName, $arrUsers)) {
$isValid = true;
// Or, you may restrict access to only certain users based on their username.
if (in_array($UserGroup, $arrGroups)) {
$isValid = true;
if (($strUsers == "") && false) {
$isValid = true;
return $isValid;
$MM_restrictGoTo = "../users/noAccess.php";
if (!((isset($_SESSION['MM_Username'])) && (isAuthorized("",$MM_authorizedUsers, $_SESSION['MM_Username'], $_SESSION['MM_UserGroup'])))) {
$MM_qsChar = "?";
$MM_referrer = $_SERVER['PHP_SELF'];
if (strpos($MM_restrictGoTo, "?")) $MM_qsChar = "&";
if (isset($_SERVER['QUERY_STRING']) && strlen($_SERVER['QUERY_STRING']) > 0)
$MM_referrer .= "?" . $_SERVER['QUERY_STRING'];
$MM_restrictGoTo = $MM_restrictGoTo. $MM_qsChar . "accesscheck=" . urlencode($MM_referrer);
header("Location: ". $MM_restrictGoTo);
exit;
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_update"])) && ($_POST["MM_update"] == "form2")) {
$updateSQL = sprintf("UPDATE company SET name=%s, adress=%s, postalcode=%s, phonenr=%s, url=%s, email=%s, category=%s, ranking=%s, info=%s, image=%s, addon=%s, userID=%s WHERE companyID=%s",
GetSQLValueString($_POST['name'], "text"),
GetSQLValueString($_POST['adress'], "text"),
GetSQLValueString($_POST['postalcode'], "text"),
GetSQLValueString($_POST['phonenr'], "int"),
GetSQLValueString($_POST['url'], "text"),
GetSQLValueString($_POST['email'], "text"),
GetSQLValueString($_POST['category'], "text"),
GetSQLValueString($_POST['ranking'], "text"),
GetSQLValueString($_POST['info'], "text"),
GetSQLValueString($_FILES['image']['name'], "text"),
GetSQLValueString($_POST['addon'], "date"),
GetSQLValueString($_POST['userID'], "int"),
GetSQLValueString($_POST['companyID'], "int"));
mysql_select_db($database_connamsterdam, $connamsterdam);
$Result1 = mysql_query($updateSQL, $connamsterdam) or die(mysql_error());
$updateGoTo = "../users/user_specs.php";
$updateGoTo .= (strpos($updateGoTo, '?')) ? "&" : "?";
$updateGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $updateGoTo));
$colname_rs_editCompany = "-1";
if (isset($_GET['companyID'])) {
$colname_rs_editCompany = $_GET['companyID'];
$query_rs_editCompany = sprintf("SELECT * FROM company WHERE companyID = %s", GetSQLValueString($colname_rs_editCompany, "int"));
$rs_editCompany = mysql_query($query_rs_editCompany, $connamsterdam) or die(mysql_error());
$row_rs_editCompany = mysql_fetch_assoc($rs_editCompany);
$totalRows_rs_editCompany = mysql_num_rows($rs_editCompany);?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../uploads/",
'FileName' => "[FileName]",
'DefaultFileName' => "".((isset($_POST["default"]))?$_POST["default"]:"") ."",
'ResizeType' => "1",
'ResizeWidth' => "240",
'ResizeHeight' => "180",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1_2 Start
$WA_UploadResult1_Params["WA_UploadResult1_2"] = array(
'UploadFolder' => "../uploads/thumbs/",
'DefaultFileName' => "",
'ResizeWidth' => "100",
'ResizeHeight' => "80",
// WA_UploadResult1_2 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["submit"])){
WA_DFP_UploadFiles("WA_UploadResult1", "image", "0", "", "true", $WA_UploadResult1_Params);
thnx,
Tom.
you are using the Dreamweaver Update record behavior on this page.
The limitation to the dreamweaver update record behavior, is that it can only use form data.
It cannot use the Server File name variable that is created by the upload behavior to hold the name of the uploaded file.
you will need to use the Data Assist Update record behavior for this.
t.weijers438628
ok
Ok, thnx.
is that included in digital file pro?
Tom.
No, it is included in Data Assist or Data Bridge.
