Can't Get POWER CMS to Work Locally Either
Thread begun 5/02/2012 8:43 am by axisbold2k2 | Last modified 5/02/2012 10:34 am by Jason Byrnes | 1282 views | 1 replies |
axisbold2k2
I think the WebAssist products are a great idea.
But I am having repeated trouble with PCMS. I have installed
Security Assist first with no problem and then installed PCMS.
PCMS broke everything.
I have tried connecting remotely which I can no longer seem
to do. And now I have tried to install locally using XAMMP and
WAMP.
First I had to enable CURL which on the INET(GOOGLE) says is
done with only 1 file. I had to enable CURL in:
php.ini-development
php.ini-production
php.ini ( in the PHP folder)
php.ini (in the Apache folder)
phpForApache.in
and finally it worked.
Now as I try to run the CMS setup locally I can get to the 3rd Step of the installation
Wizard requiring Database Info. I've tried to run using "root" with no password; "root" with a password; adding a new user with a password and all I get is stalled installation.
You have a pdf document located here:
powercms/
which talks about uploading solution pack files but I can't seem to find this anywhere. Is this for an older version?
I can't seem to get SECURITY ASSIST to work either. Isn't there some way to install these products without using the WIZARDS? I'm very frustrated as I purchased Super Suite and am stalled trying to get sites done for clients too.
By default the root user that WAMP creates does not have a password set, however, POWER CMS will not except a blank password since this is not a common occurrence on live servers.
I found this video on youtube that walks through configuring the root password for your wamp server:
watch?v=sw6rd75sWR4
there is an issue using PowerCMS on security assist pages, see this post for details on fixing the problem:
showthread.php?t=15730
