Security Assist /PowerCMS Conflict? - Fatal Error
Thread begun 9/03/2010 1:49 am by neilo | Last modified 6/05/2012 12:06 pm by Jason Byrnes | 9270 views | 10 replies |
neilo
I swear I can break stuff just by thinking about it.
I had a fully functioning site late yesterday, after sorting out the paths problem with Security Assist, but after adding the developer code from CMS to the regular pages, I am not able to access any of the protected pages (in an 'admin' directory in the site root) because of an apparent conflict between the CMS' and Security Assist's 'Helper_PHP.php' files.
This is the errorI get when trying to access any of the protected files in the admin folder:
"Fatal error: Cannot redeclare wa_authenticateuser() (previously declared in /home/users/uks45031/html/katelissauer.com/WA_SecurityAssist/Helper_PHP.php:10) in /home/users/uks45031/html/katelissauer.com/cms/WA_SecurityAssist/Helper_PHP.php on line 48"
No code has been changed in any of the Security Assist pages or folder, or on the protected pages, since it was working beautifully. Only the developers code has been added, which seems to have caused the problem.
The CMS folder (cms) and the Security Assist folders are both in the root directory.
Should I just I just redirect the CMS page includes for the Helper_PHP.php file in the SecurityAssist directory in the 'cms' folder to the SecurityAssist directory in the root folder?
Help on this would be greatly appreciated.
P.S. - I can log in to the CMS without any difficulty.
in the WA_CMS/WA_CMS.php file, comment out the securioty assist include line:
//require_once( "../WA_SecurityAssist/Helper_PHP.php" );
the security assist helpers are used for the live edit functionality, this will create a conflict on pages that have security assist applied.
If you want to maintain live edit on the other pages of you site you can create a copy of the WA_CMS.php file and comment the security assist line there, but leave it intact in the the other version. then in the developer notes for the security assist pages, attach the WA_CMSCopy.php page instead of the one that has the security assist include intact.
neilo
Nice one Jason, thanks for that. All is good and I can have a relaxed weekend now.
you're welcome.
lesMatthews
Is there not a way to overcome this and have live edit on an SA protected page?
Not without hand editing the security assist HelperGroupRules.php page and copying the rules from the cms version to your security assist version, this can cause conflicts however if you have rules defined that use the same name.
rik.forgo
Pwer CMS/SecurityAssist conflict ... still an issue?
I'm running into this same errors here. This post was from 2010, is this still an issue today? I'm a little confused about the work-around. I would like to have the Live Edit capability, but some pages need to be secured. Is there a better way (yet)?
evansg7124312885
This solution helped, but I have a new problem
My initial problem looked just like initial post; I found this and tried it and now have a new problem after entering log in.
Commented out code as shown in Jason's post, put to test server and refreshed. Page loaded this time, filled out log in and clicked submit and and here is the error statement I got:
Fatal error: Cannot redeclare wa_authenticateuser() (previously declared in /home/content/76/8871376/html/dev/webassist/security_assist/helper_php.php:28) in /home/content/76/8871376/html/dev/WA_SecurityAssist/Helper_PHP.php on line 46
I see now that it looks just like my first error. It did appear to change that I got the log in screen.
Second question:
I can see a new table was added to my database for this site, that was not expected. When I ran set up, there were no errors or other surprises. When I look at the new table, there is only 1 field in it. Is there any documentation on what should be created within the database (fields, properties, nulls, etc)?
I am using Design Extender 1.0.6, Mac Lion, and DW 5.5
danielsebas
redeclare issue
Hi Jason, this issue has some years now, I manage to overcome it by adding the code:
if (!function_exists(function_name)) {
in all helper files and also the mail files.
I updated to Data Bridge and Design Extender and the issue is still present when you build the site using the Build Site option with CMS, Security Assist pages and framework.
Is there any plans in solving this issue in an update?
