Info Bubble and Zoom levels
Thread begun 2/06/2012 3:14 pm by sandy170299 | Last modified 3/29/2012 10:17 am by Jason Byrnes | 5865 views | 9 replies |
sandy170299
At one time, I knew how to fix these issues, but I can't find the insructions any longer. On this page index.cfm, how can I set the zoom levels differently and how can I have the info bubble NOT appear when the page loads. Thanks!
for the Info bubble, enable the option for driving directions, but do not enter an address. that will hide the bubble when the page is loaded.
for the zoom level, see the "How to set the Zoom Level" tutorial in the how to section of the pro maps support page:
pro-maps-for-google/
sandy170299
"For the Info bubble, enable the option for driving directions, but do not enter an address. that will hide the bubble when the page is loaded."
I tried this, but directions still showed up on the page, even though I didn't enter anything. I only clicked the driving directions check box. Is there a way through the code to eliminate the info bubble on load? Thanks!
the only way driving directions would display is if something where entered in any of the address fields, including the country, leave them all blank.
it is possible to comment the code that shows the info window as well.
in the code, look for any line that starts:
marker_0_<int>.openInfoWindowHtml...
where <int> is an incrementing integer and comment it out.
john218811
I too am having problems hiding the bubble AND adjusting the zoom.
I'm working with dynamic content so my wagmp_map_x file is php. I can remove the bubble by enabling the option for driving directions with no data entered.
But if I then follow the help here pro_maps_set_zoom_level_ht.pdf the map detail disappears and I get the dreaded grey box - villa-resorts.php
Any ideas?
instead of adding:
map.setZoom(8);
try finding each instance of;
map.setCenter(point, 13);
and changing it to:
map.setCenter(point, 8);
john218811
Thanks.
Tried that villa-resorts.php
Map shows but still at default zoom.
I want it to load to show all 5 markers.
change this line:
map.setCenter(wagmp_map_9_obj.points[0], 13);
map.setCenter(wagmp_map_9_obj.points[0], 8);
john218811
Bingo! Thanks.
you're welcome.
