Please help- i only have 2 hrs to fix this?!?!?
Thread begun 12/06/2011 10:28 am by sales189614 | Last modified 12/06/2011 11:51 am by sales189614 | 1706 views | 3 replies |
sales189614
I have a ticket open (#135314), but as usual support is slower than molasses.
I am in desperate need of help. I have been getting support to get PowerCMS Builder working properly for 4 weeks now, and I have (hopefully) one last issue to fix.
I am meeting with my client at 2 pm (in just 2 and a half hours from now) and I'm afraid that support won't get back to me before I have to meet with my client. You might say, reschedule right? I can't because this client is so frustrated with the time it has taken to get this to work on his site, that they will not give me anymore time. So here is my issue, if someone out there can help me, I would REALLY, REALLY appreciate it:
When I converted all of the pages for this site to use the editor, I copied and pasted the coding to go into the content area into the code editor of the cms editor, then pasted the developer coding into the page and uploaded the page to the site using my non-Dreamweaver FTP client. I didn't copy and paste the text and add styles in the wysiwyg part of it, I did it all using code view.
So now, in a new or existing document, any new text I add that I do in the wysiwyg part, I type the text and it has no style to it of course, as it should be, then I select the text that I want to apply a style to and apply the style to it, but it applies the style to all of the text that comes after the text I had just selected and applied the style to as well. If I select any text after the text I just applied the style to, then it applies the style I just selected for that text to the text before it as well. Basically, it will not let me apply different styles to any text I add to a document WITHOUT MANUALLY DOING IT IN CODE VIEW. It applies the style to all the new text instead of letting me select say one word and apply a style to it, then select the word after it and apply a different style to it, as an example. It will only allow one style.
Obviously my client is not going to be able to do this in code view when they need to add new text to a new or existing page, because they do not know html, and need the ability to use the wysiwyg editor, that is the whole reason for the cms program afterall, so I need to find a fix for this right away.
Has anyone had this issue or know how to fix it? Users? Tech support? I'm sure it's something simple, but I don't know what and I am running out of time FAST.
Thanks!
sales189614
Oh I forgot to mention, it will allow me to apply different styles to different text if the text is in different paragraphs, but not text within the same paragraph, if that makes sense? I need to be able to apply different font styles to different words in the same paragraph without having to do it in code view. Sorry, I just wanted to clear it up just in case.
I have forwarded this to Ray, he should be calling shortly to look into the issue.
sales189614
Thank you!
For anyone who needs it, the solution was in the default.js file (webassist/ckeditor/plugins/styles/styles/default.js), you have to change the h3's to span's, for example:
element : 'h3',
to
element : 'span',
That solved it for me. Thank you Ray.
