javascript error
Thread begun 7/20/2011 9:22 am by edrosenthal350859 | Last modified 2/17/2012 9:18 am by Jason Byrnes | 2741 views | 5 replies |
edrosenthal350859
javascript error
i got the thing working and was able to add content. but on the second page i want to put into cms i get the error
"while executing applyserverbehavior in wapcms_contentnode.htm, a javascript error occurred."
i immediately removed the cache dat file and restarted dw cs4 and saw the error again.
suggestions?
by the way i thought i had two connections, but now i have only one, although it is a duplicate of the one i thought i had originally. it looks correct though.
then when i wente to the remote site and to the admin area, i saw the content there. so now i am thinking the error was in the placing of the developer notes on my local copy of the file. to do that i must apparently have to do that manually, until this error is fixed???
on the other hand, perhaps i need to do some other thing i haven't yet discovered. more from the diary later.
jamie424562
Have the same error msg
I am having to use the Powercms in CS5 and receive this error msg.
have cleaned cache but is the same.
Have CS5.5 and there the menu option doesnt even display so cant even try and use it there.
help pls.
This error usually happens if you are trying to add Power CMS builder to an HTML page, you will need to use a php page instead.
In CS5.5, go to Commands -> Manage Extensions, do you see Power CMS Builder as an installed and active extension listed there? if not, you will need to install it to the CS5.5 extension manager (make sure to close Dreamweaver while installing extensions)
jamie424562
was trying to insert into a php page, and yes also see the extension installed.
still no luck with this.
any other suggestions, having to reinstall all plug ins every other month is really painful and annoying.
