ecart content in email
Thread begun 6/28/2011 5:25 am by ijs174940 | Last modified 6/28/2011 9:18 am by Jason Byrnes | 2472 views | 5 replies |
ijs174940Beta Tester
Seam to be having problems adding any dynamic content to an email template in UE,
Previously I made a email friendly page and added all the dynamic content with recordset and then added it as a template in UE but for some reason the paths in the template are not being updated via the include so it fails on the first line saying it cannot find the path to the db connection file.
I even tried not using a template and selected the DW edit button then used the framework to include the correct email template thinking that would update the path correctly but still get the same outcome.
At the moment I cannot send a copy of the completed ecart contents to the server admin which is causing no end of problems.
Am I missing something obvious?
Universal Email will not update paths to include files in the email template, the paths to the include files need to be corrected in the template manually.
Is it no possible to have a blank template set at the correct level in the site in relation to the file library for UE and then use framework to include the dynamic template? If not what is the best way to incorporate the contents of the cart in the email? I need it send multiple email on payment completion
best way to have eCart content in the email is to not use a template.
in the UE wizard, do not select the option to create a file for the email, instead, click the Dreamweaver edit icon to design the email directly in Universal Email.
I tried that and used the framework include there but it still threw errors, are there any support articles on this feature between the two extensions?
do not use the framework include.
use the Dreamweaver design view to create the email message.
