WAFV... error - Client Validation Wizard
Thread begun 6/06/2011 8:32 am by Dennis | Last modified 6/09/2011 6:56 am by Jason Byrnes | 4575 views | 9 replies |
Dennis
I have created a form for members to upload photo's. I would like to make the file field required. I have used Spry to validate all the other fields in the form. It appears to me that the WA Client Validation tool is what I would use for this (validateing file field).
Would you agree that that is the appropriate tool?
When I attempt to use the tool I get numerous WAFV... JavaScript errors. I have tried after deleting the DW cache file.
I also have some questions regarding the File Manipulation Wizard, I am not sure when to post it, I don't have a clue which of most of the WA products I have that it belongs to. If this is the wrong place please direct me to the correct forum.
I would like to rename the uploaded files to something like photo_001, photo_002, etc so that thw photos become anonymous, how might I do that?
What is, and how would you use the "Default file" field displayed at Step 2 of 2 (Specify file output options) of the File Manipulation Wizard? See attachment screen shot.
How might I update a database column with the renamed file name?
Disregard the above question. It is answered in a step I missed in your document "Adding Digital File Pro to DataAssist..."
Also attached is a screen shot of the error and the page I am working with.
Dennis
No, client validation should not be used to validate a file field.
You should use server validation for validating a file field.
as for file manipulztions, they are intergated intyo Form Builder 2 and Universal Email.
on the first page of the wizard set the option If file exists: rename new.
then on the second page, change the File Option from "[FileName]" to "photo"
this will cause the first file to be uplaoded as photo.jpg the next as photo_1.jpg, etc.
the default file is the value that will be give to the Server File Name when a file is not uploaded.
see the "Adding Digital File Pro to DataAssist.." tutorial, specifically the update page section for details.
Dennis
A little more detail please
Thanks Jason,
I could use a little more specific's please...
Should I select the (file) field from the lsit of form fields. I'm afraid I haven't yet got the hang of when to use Server, Session or Form variables. So the options under the lightning bolt make my head spin.
You don't mention what if anything to have in the Rename to:
Using the settings show in the attached image, only the first save uses my photo_101 prefix. Subsequent saves resort back to the flename_increment. I was shooting for photo_101_1, photo_101_2.
Thanks,
Dennis
Yes, select the File Field from the form binding collection.
For the rename new option, leave the default [FileName]_[Increment]
the [FileName] portion will use whatever you set for the File name setting in the second step.
it is not possible to set a seed value _101 value like you are trying to do.
the first file uploaded will be name photo_101 on uploading other files, since photo_101 exists, it will be renamed _1:
photo_101_1 etc... the first upload will not be renamed however, since on the first upload, the file does not exist.
Dennis
Jason,
The photo_101_1 is fine, thats what I would expect. However it isn't working that way.
Dennis
you have three copies of the image being created, the first one still has the name set to [FileName] instead of photo_101
Dennis
Jason,
Thats correct, but the files saved in the other two folders (Large, Thumbnail) are named as I described. The third folder (Original) is where I want to store the original file with the original filename.
Dennis
Dennis
Problem Resolved
Jason,
I discovered what my problem was.
There appears to be a bug with the File Manipulation Wizard. On Step1 if you change the Action: to lets say Reaname existing file, then change it again to Rename new file, it retains [ExistingFileName]_[Increment], it does NOT enter [NewFileName]_[Increment].
I had noticed that but in correcting it I entered [FileName]_[Increment] instead of [NewFileName]_[Increment].
Sorry for the inconveience and thank you for your help.
Dennis
OK, glad to hear it is working.
