Not showing multiple points at same address
Thread begun 10/20/2010 1:57 pm by mallardnj111947 | Last modified 10/25/2010 7:24 am by Jason Byrnes | 2478 views | 5 replies |
mallardnj111947
Hello all,
My map is mostly working, however if I have multiple instances of the same address, it only appears to show one of the records. ASP VBScript Recordset. Is this normal behavior or user error? Thanks in advance!
Yes, multiple instances of the same address will use the same marker position.
mallardnj111947
So is there any way to know/view the other records (the ones below the one that is showing)?
see the "How to change which address your map centers on" tutorial on the pro maps support page:
pro-maps-for-google/
mallardnj111947
Hi Jason,
I've read that tutorial, but that doesn't address my problem. The issue is that if there are multiple records with the same address, there does not appear to be a way to see all of them or click on any of them except the topmost one. In other Google maps, when you click on a point it either explodes out to show you the multiple points at that address or multiple records will appear in the popup and you can scroll in that box to review all records at that address.
Using the tutorial i linked to, you can create a link for each address. When you click the link, the info window for that particular address will be shown. this should address the issue you are facing.
If it is not working for you, please post a link where i can see the issue to debug it.
if your addressees contain apartment numbers for the street, like "101 fake st. Apt. 1" this will cause the address lookup to fail, which would also cause the link to fail loading the info window.
