PowerCMS 2.01 - removing buttons in ckeditor
Thread began 8/20/2010 2:20 pm by gatewoodj357467 | Last modified 8/23/2010 8:34 am by Jason Byrnes | 2831 views | 3 replies |
gatewoodj357467
I want to create a 'custom' toolbar in the ckeditor by removing many of the existing buttons (to limit confusion).
I did some reading online, and found the "Default" toolbar config in the fckeditor_config.js file within the HTMLEditor directory, but changing/commenting out values in that portion of the file does not cause anything to change on the editor toolbar.
I also noticed that a custom configuration js file can be put together and referenced with a path statement at the beginning of that file (I haven't tried that yet, but that will be my next step).
Is there any info. you can provide as to the simplest method to pursue (where the parameters are located :: file & path) to change the default toolbar button set?
look in the HTML_Editor/custom foldser.
there is a seperate .js file the insert and the update page.
In each of those js files, the toolbar is defined using this code:
FCKConfig.ToolbarSets["Custom"] = [
['Source','DocProps','-','Save','NewPage','Preview','-','Templates'],
['Cut','Copy','Paste','PasteText','PasteWord','-','Print','SpellCheck'],
['Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'],
['Form','Checkbox','Radio','TextField','Textarea','Select','Button','ImageButton','HiddenField'],
['Image','Flash','Table','Rule','Smiley','SpecialChar','PageBreak'],
['FitWindow','-','About'],
['Bold','Italic','Underline','StrikeThrough','-','Subscript','Superscript'],
['OrderedList','UnorderedList','-','Outdent','Indent'],
['JustifyLeft','JustifyCenter','JustifyRight','JustifyFull'],
['Link','Unlink','Anchor'],
['Style','FontFormat','FontName','FontSize'],
['TextColor','BGColor']
]; /* Toolbar end */
you can re,move the names of any of the buttons you do not want to include.
gatewoodj357467
Thank you for the quick response.
I have modified both the insert and the update .js files in the custom folder, uploaded them to the web server, cleared my browser's cache (tried multiple browsers), yet the changes are not reflected in the editor online.
What could I be missing?
if it is not changing online, my first guess is that the changed insert and update .js files are not properly uploading to the server.
Try deleting them from the server, then re uploading them.
