CMS 1 to CMS 2 upgrade
Thread begun 5/18/2010 4:53 pm by zanimul379168 | Last modified 5/19/2010 4:40 pm by Jimmy Wu | 1940 views | 1 replies |
zanimul379168
Okay, two prong question here, if I opted to upgrade one of my sites from V1 to V2, does that have any affect on the licensing of other sites that I have V1 installed?
Second part, what is the process to upgrade from V1 to V2, is merely copying the new files to the site enough?
And if I can add one comment, I'm just a bit dismayed to find out about the new licensing policy of PowerCMS. My own fault for not reading deeper, but I purchased the new version with intentions of being able to update the two sites that are currently using it and set up a third. So now I have to explain to my clients that they have to pay for an upgrade. Sigh. I still love your products, but can't you cut us long time users a bit of break?
Jimmy Wu
If you upgrade one of the sites, the licensing on the other site is not affected.
To upgrade, you would want to put the CMS2 files in a different directory from the first CMS and then run through the wizard. The wizard will set up everything for your CMS to work. As always, I recommend making a backup of everything before making any modifications to a site and/or database.
