DataAssist Search: change form element
Thread begun 5/13/2010 12:14 pm by mr hankey | Last modified 5/14/2010 12:22 pm by Eric Mittman | 1458 views | 1 replies |
mr hankey
What is the best way to create a drop down menu which will change the results on the page?
Say for example i have an employees recordset on my page which shows:
first name
last name
dob
Country
salary
i want to create a menu which would then change the recordset to show salary = 30000 or 40000
Do i have to create multiple recordsets with a WHERE clause that when the menu selects that it changes to the where clause and if so how do i achieve this?
Many thanks
You should not have to do any manipulation of the sql or recordset to achieve this. The best way to go about this is to start with a search form that is searching this column in the recordset. So you should setup the search criteria on your results page first, ensure that you are searching the correct column and that you are looking for a numeric value that is equal to the entered value. For the entered value put the form field that the value should be entered into.
Once you have it working with a regular input you can then update it to be a select list. You just add in the labels and set the values to the values that you want to search on. If you want to make it update the results automatically is more advanced. You will need to add some js code into the onchange event that submits the form.
