Upload not available
Thread begun 4/22/2010 7:41 am by mdsayeed_u394092 | Last modified 6/02/2010 9:44 am by Jason Byrnes | 2842 views | 5 replies |
mdsayeed_u394092
Please check this issue, I am not able to upload images
can you please give us some more details.
Please describe what happens when you try to upload an image.
we will need more information on the nature of the problem to be able to look into the cause of the problem.
info263954
Same error message
Hi i have the same error message.
I have ticked 'Enable File Management' within the Global Upload Settings section, and set the folder to /uploads/
then when i click the image icon in the actual editor, then click on the upload tab, it states... "upload not available". so you don't even get the browse files form field.
The folder itself has permissions set to 777.
its on a linux server.
Thanks,
Jeremy
for file upload to work, there are 2 steps you must follow.
1) Enable file management in the global Site Settings.
2) When Applying the HTML Editor instance, either select one of the presets with file management enabled, or click the Customize button and check the Allow File Upload options.
You will also need to check the Allow Advanced Image Editing option if you wish to use the Advanced image editing functions.
tlshoaff392246
Did this work?
I'm still having the same issue and cannot get my image to preview. Please help...I'm down to the wire on this project.
Thanks.
following those 2 steps should get file upload working.
Sometimes making changes to the HtML editor configuration will not take effect immediately in the browser until the cache is cleared. try closing the browser, then clearing the cache and trying again.
