SiteAssit Directory
Thread begun 3/08/2010 1:08 pm by Laurent | Last modified 3/09/2010 3:37 am by Laurent | 1858 views | 2 replies |
Laurent
SiteAssit Directory
I am new to SiteAssit and just tried to generate an Administrative Backend Site.
I had an existing site, and i prepared and directory called /backoffice with a file named index.php in it. I opened it, ran SiteAssist, choose Administrative:All Layout, finished the process, thinking wow, that's a great product !
For sure it is, but how frustrating it was to see my existing homepage was overwritten without notice in the / of the site and all the files were generated directly into the / too !?
I would like to store these files in separate protected directory (via .htaccess) and be able to edit them again. So saving file by file into the directory is not a good solution...
So, is there a way to do this ? At least i would create a subdomain but this is not the best way. The product would have been perfect with a simple field asking where to generate the pages...
neilo
H Laurent,
A safe way to do this would be to create a duplicate site definition of your site, and edit it to make the local root and testing server root folders point to the backoffice/ directory.
You would just need to append 'backoffice/' to the end of the existing paths. This would force SiteAssist to place the files and folders in the backoffice folder.
Laurent
Thank you that's a good idea !
Best of all i suppose it would work in any similar cases... ;-)
Regards
Laurent
